Author Topic: RIP workflow  (Read 6590 times)
RIP workflow
« on: Sat, 22 April 2017, 16:30:44 »
http://www.ssega.com/
the other systems are on the right
Re: RIP workflow
« Reply #1 on: Sat, 22 April 2017, 19:13:43 »
is this website replacing a website called workflow.
or is this website going to make you NOT WORK..
/clarification request
Offline Jaymanlp
Re: RIP workflow
« Reply #2 on: Sat, 22 April 2017, 19:50:38 »
Looks like it'll make you not work.
Sent from my ASUS_Z00TD using Tapatalk
Offline SBJ
  • Tactile pls
Re: RIP workflow
« Reply #3 on: Sun, 23 April 2017, 03:47:56 »
I'm hoping this isn't blocked when I get to work on Monday.  :p
Re: RIP workflow
« Reply #4 on: Sun, 23 April 2017, 04:22:41 »
Get ready to be fired for catching a virus @ work..
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: RIP workflow
« Reply #5 on: Mon, 24 April 2017, 06:56:59 »
Oh god. ROM files are all laced with STDs. Not even Abandonware DOS games are safe :(
If I could play Flash Games I would totally trust them before I trust ROM files again. Hmmm.. maybe I should load up Chromium..
Offline SBJ
  • Tactile pls
Re: RIP workflow
« Reply #6 on: Tue, 25 April 2017, 02:57:15 »
Won't somebody please think of the CHILDREN!!
In either case, I never loaded up the website at work. Figured it was best to just, not do it.
Re: RIP workflow
« Reply #7 on: Tue, 25 April 2017, 21:50:41 »
If it's allowed through the filter where I work you can bet it's safe. One of the few Flash-based sites I can even access at work.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: RIP workflow
« Reply #8 on: Wed, 26 April 2017, 07:10:21 »
IIRC Google is pretty good about patching Flash exploits. idk about Firefox. I switched to Chrome a few years ago for syncing
