Author Topic: Common post I'm sure: Need helping finding my ideal gaming board  (Read 3093 times)
Offline disposalist
I've recently been looking to replace a Microsoft Sidewinder X4 and had a real tough time meeting my criteria.  Geekhack came up a lot in my research ;)
I have 5 criteria and it seems there is nothing suitable: -
Compact (either TKL or the numpad/arrows hybrid. It's uncomfortable to shove a long keyboard left or hold the mouse farther right)
Quiet (I don't mind if this means *horror* membrane or some new MechaMembrane or dampened mechs)
Slidey (Odd word, but it combines Low Profile, non-matt and sloping sided. For gaming I need to slide or roll from key to key)
Anti-ghosting (Again for gaming. 5 keys at least really)
Quality (They can't be breaking or not actuating properly or being weird.  Must be wired.  Should have lettering that can't scratch off)
One nice-to-have: -
Ergonomic (I like to tilt my board to the right so my gaming WASD grip is angled with my hand, but still need to type messages quickly. Tricky)
So far I've tried 8 boards.  'Gaming' boards are almost ALL mechanical these days and getting the more exotic switched versions nigh on impossible.  Want an orange Razor or a silent Cherry?  Go fish :(
The only ones that get near - and you guys will be disgusted - are: -
Keysonic KSK-6001UELX
I know, I know.  Ugh.  I'm using it right now, though and it's not bad...  I 'm ashamed.  It is compact, though has a weird layout of the arrow/nav keys, they are all there and the keypad too.  It's anti-ghosting which is rare for a cheap keyboard.  It's mid-capped and they are not grippy though not glossy.  It's membrane so it's quiet but the case is also nicely 'dead' acoustically.  It has double injected caps.
The only issue I've had thus far is holding down keys and wiggling that finger can 'unactuate' but sticking a bit of paper inside so it presses down further has fixed it.  Yes, it can even be modded somewhat!
Roccat Arvo
Another membrane board!  Haven't got one yet - the eBay auction ends in a few hours - they are no longer produced!  I imagine it will be much the same as the Keysonic but have better quality and a couple of features like macro keys.
I tried various other keyboards.  Mechanical Cherry MX Red and Brown (quite noisy even O ringed).  Mecha-membraned Razer (but it was full size and shad an irritating high frequency click).
My highest hope was to take the Cherry MX 3.0 board mid-caps and put them on a Cherry MX Brown switched board with O rings.  One of the keys didn't fit and the caps were not the quality I'd hoped.
If you guys don't help me, I'm going to be stuck using a £30 Keysonic until is breaks, then buying another and another (at least they are cheap enough).
Cheers!
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
Re: Common post I'm sure: Need helping finding my ideal gaming board
« Reply #1 on: Wed, 10 May 2017, 11:07:30 »
This is the part that's gonna get you. The rest are normal wants in KBs, but the specific caps you're describing here don't seem to be something in production for anything other than scissor switches or rubber dome. I could be wrong and more power to ya if someone finds them.
And actually Im pretty sure that with the way most mechanical switches work this would be difficult to achieve even with the right caps.
Maybe MX speed?
What kinds of games could you be playing that demand the kind of finger movement like that anyway?
« Last Edit: Wed, 10 May 2017, 11:15:03 by DudeSnail »
« Reply #2 on: Wed, 10 May 2017, 11:09:37 »
I wonder if these caps would be considered 'slidey'
http://pimpmykeyboard.com/g20-stealth-keycap-set/
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #4 on: Wed, 10 May 2017, 11:15:22 »
He said non-matte though
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #5 on: Wed, 10 May 2017, 11:15:45 »
Ergodox
I know you wanna shill, tp, but I'm pretty sure this matches almost 0% of his criteria
« Reply #6 on: Wed, 10 May 2017, 12:49:31 »
Ergodox
The Ergodox meets and exceeds all the criteria..
It is the ONLY ergonomic keyboard choice for today's Competitive gamer.
Offline disposalist
« Reply #7 on: Wed, 10 May 2017, 16:01:24 »
Those actually look pretty good!  I'm in the UK though... I think we just do not get the same service when it comes to modding suppliers :/
Offline disposalist
« Reply #8 on: Wed, 10 May 2017, 16:07:11 »
Maybe MX speed?
Battlefield 1 lately but lots do.  Imagine holding "W" to run forward, alternating "A" and "D" to strafe left and right as you run (evade those snipes) then needing to jump a wall (Press "SPACE") and change to a sidearm (Press "2").  That sidearm change while maintaining a run means I need to slide my middle finger up on the "W" to the "2".  A similar scenario needs to slide from "W" to "E" to enter a tank on the run.
Modern shooters are crazy.
I tried playing Battlefield 1 on a mechanical board with brown switches and normal 10mm boxy caps and I was nearly deafened and crippled ;)
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #9 on: Wed, 10 May 2017, 21:07:31 »
Maybe MX speed?
I do similar things without the need to "roll" or "slide", but we all have our own playstyles I suppose lol.
The g20 caps posted earlier are going to be your best bet, but they are matte on top of each key.
Offline quasistellar
« Reply #10 on: Thu, 11 May 2017, 09:15:48 »
Maybe MX speed?
Could try a board with MX Speed switches and get some of those weird flat keycaps from SP?  EDIT:  looks like someone already mentioned the G20 caps from SP.
