Author Topic: IMPORTANT PSA: INSTALL WINDOWS UPDATES ASAP  (Read 6587 times)
Offline Encabulator
« on: Sat, 13 May 2017, 09:52:47 »
I know most of you have probably heard about this but just in case not, better to be safe than sorry. I won't be going in depth but basically the NSA had their windows backdoor leaked which allows someone to execute files without you clicking anything. A group of people made a virus using this and your computer can catch this ransomware that will encrypt all your files. Please install windows new patch for this backdoor as soon as possible. You can catch this worm by being on the same network as someone with it.
relax bro.. no one will bite ur head off on geekhack.. this is not that kind of community...   hahahahahahaha
Though tp4 will personally chew you out if you start selling $60 orings.
Offline Coreda
Re: IMPORTANT PSA: INSTALL WINDOWS UPDATES ASAP
« Reply #1 on: Sat, 13 May 2017, 11:01:07 »
Here's a Github page that details what the WannaCry∕Crypt ransomware is, how it propagates, along with news and updates.
« Reply #2 on: Sat, 13 May 2017, 11:05:07 »
Oh yay...my work PC has decided windows update doesn't work anymore.
EDIT: So if I'm using malwarebytes premium I'm ok? Cause I am at work... :-X
« Last Edit: Sat, 13 May 2017, 11:09:58 by SpAmRaY »
Offline Encabulator
« Reply #3 on: Sat, 13 May 2017, 11:15:12 »
Malware bytes will most likely not prevent it being a worm that doesn't need to ask permission for anything. Hospitals have already been compromised and have had to turn away patients. Just look online for a solution when you have time. It might also be that windows is being overloaded with update requests.
Offline Encabulator
« Reply #4 on: Sat, 13 May 2017, 11:18:51 »
Do this for now. Quote from the GitHub "Kill switch: If the website www.iuqerfsodp9ifjaposdfjhgosurijfaewrwergwea.com is up the virus exits instead of infecting the host. (source: malwarebytes). This domain has been sinkholed, stopping the spread of the worm."
Offline Coreda
« Reply #5 on: Sat, 13 May 2017, 11:24:01 »
From what I've read it uses the EternalBlue exploit so if Windows Update isn't downloading atm disabling SMBv1 is a mitigation. See the comment here. I used the PowerShell command from the Microsoft link a couple days ago rather than the one listed in the comment but they do the same thing afaik.
« Reply #6 on: Mon, 15 May 2017, 22:06:04 »
But now V2 has been release which ignores the domain.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #7 on: Mon, 15 May 2017, 22:20:25 »
Disable wifi and unplug ethernet. Crisis averted. If you're running Windows XP well, install Linux Mint.
Here are some things
https://blog.malwarebytes.com/threat-analysis/2017/05/the-worm-that-spreads-wanacrypt0r/
More things
https://www.malwaretech.com/2017/05/how-to-accidentally-stop-a-global-cyber-attacks.html
« Reply #8 on: Mon, 15 May 2017, 22:32:56 »
does avast stop this bug?
I don't want to install windows telemetry..
Offline fanpeople
« Reply #9 on: Mon, 15 May 2017, 23:44:42 »
and windows telemetry doesnt want to install you either
Offline SBJ
  • Tactile pls
« Reply #10 on: Tue, 16 May 2017, 00:56:19 »
Welp that was quick.
I guess it was too much to expect, that it stayed dead.
Still I have my Windows patched so I am not expecting problems. Unless v2 also works with the patch?
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #11 on: Tue, 16 May 2017, 07:50:56 »
168511-0
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #12 on: Tue, 16 May 2017, 21:12:03 »
looks like they have a patch out for OSX as well.... my win10 box seems more concerned with 'updating my amd video driver' which is impossibly wrong.
-Dana
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #13 on: Wed, 17 May 2017, 01:39:41 »
Thought I would post this too. Decrypter for V1
BTCWare Ransomware Master Key Released, Free Decrypter Available
https://www.bleepingcomputer.com/news/security/btcware-ransomware-master-key-released-free-decrypter-available/
Offline SBJ
  • Tactile pls
« Reply #15 on: Wed, 17 May 2017, 03:10:30 »
go linux!
Heh yes Linux does seem to have less issues.
I was surprised to hear that there was a Windows patch out in March for this bug. Seems they might've been a little ahead for once?
Offline jonathanyu
« Reply #16 on: Thu, 18 May 2017, 11:34:31 »
Updated my windows first time in the past year....
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #17 on: Thu, 18 May 2017, 18:15:58 »
go linux!
How about that Linux desktop market share jump to 2% in the past year, eh?  :eek:
« Reply #18 on: Thu, 18 May 2017, 18:18:23 »
go linux!
Noo.... leave linux alone..
I want  to be the ONLY kewl kid with linux..
if everyone installs the linux,   then not only will my computer not be cool,   all the hax0rz will also shift gears ..
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #19 on: Thu, 18 May 2017, 18:27:26 »
go linux!
Linux stickers = ladies asking for your # at the Cafe
Offline fanpeople
« Reply #20 on: Thu, 18 May 2017, 18:28:58 »
go linux!
JUST ORDERED 100 LINUX STICKERS.
« Reply #21 on: Thu, 18 May 2017, 18:36:06 »
I hurd it only works if you're able to answer their programming questions correctly..
Time to memorize some obscure java scripts..
Offline fanpeople
« Reply #22 on: Thu, 18 May 2017, 18:58:20 »
I'll just tell them that my guy handles all that, frees up my time for looking at cat pictures and wishing i could play Bf1 on my incompatible machinery
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #23 on: Thu, 18 May 2017, 19:06:30 »
dang
« Reply #24 on: Tue, 23 May 2017, 22:00:34 »
Did you get more than 1GB updates and about 7 reboot cycles like I did? :))
« Reply #25 on: Tue, 23 May 2017, 22:18:57 »
I installed the update, but it didn't actually run until 2 days later. Despite it saying it would run immediately after installation.
Offline jonathanyu
« Reply #26 on: Wed, 24 May 2017, 00:37:19 »
i got like 5gb update
i left my computer on for update in the morning
and when i got home after school in the afternoon its still rebooting
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #27 on: Wed, 24 May 2017, 09:11:57 »
ARE WE SAFE? I WANNA CRY!
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #28 on: Wed, 24 May 2017, 10:55:46 »
Nope
Offline SBJ
  • Tactile pls
« Reply #29 on: Wed, 24 May 2017, 14:01:57 »
You will never be completely safe with Windows.  :p
Offline digi
  • elite af tbh
