Author Topic: Keyboards that you can mod switches without desoldering  (Read 3807 times)
Offline phinix
« on: Sat, 13 May 2017, 12:34:27 »
Which keyboards manufacturers can have their switches moddified without desoldering?
I wanted to open switches on Filco but I think these need to be desoldered..
Ideally, I'm after ISO TKL keyboard that I can open switches without desoldering...
« Last Edit: Sat, 13 May 2017, 13:01:21 by phinix »
Offline Targa-TV
Filco MJ2 Black - MX Red | VA88M - MX Brown | Cherry G80-3000 -
  MX Blue | Cherry G80-3000 - MX Black | XD75re - MX Silent Red
[image]http://i.imgur.com/our8YUc.png[/image]
Offline klennkellon
  • I like bottoming out
Re: Keyboards that you can mod switches without desoldering
« Reply #2 on: Sat, 13 May 2017, 16:29:11 »
Glorious's Modular Keyboard or the Team Wolf Zhuque, both have switches you can just pop out and in without any soldering.
Offline davkol
  •  Post Editing Timeout
« Reply #3 on: Sat, 13 May 2017, 17:26:58 »
Plateless keyboards with PCB-mounted MX-compatible switches.
Keyboards with plate-mounted MX-compatible switches and special cutouts in the plate. Those are only custom.
Keyboards with sockets for switch swapping on the PCB (and a special plate, presumably).
Keyboards with Alps SKCM/SKCL switches or respective clones.
So, _almost_ any Cherry G80, some vintage keyboards like Chicony KB-5191, Uniqey keyboards, the few hot-swap keyboards and some customs. Also, pretty much anything with complicated/simplified Alps or clones like Matias switches.
Offline flashquark
    • Flashquark.com | Mech Key Depot
« Reply #4 on: Mon, 15 May 2017, 11:49:31 »
Check out this thread to learn more about the plate cutouts:
https://geekhack.org/index.php?topic=59837.0
https://flashquark.com | Keyboards, Keycaps, Switches, and other MK accessories.
Offline J-Bird
« Reply #6 on: Sun, 10 September 2017, 23:07:54 »
There's also the Kananic (德柯达) L82/S82 except the black non-backlit version (note that switches can be replaced on the white non-backlit version, as well as on all the backlit versions).
