Author Topic: I had a dream! And it was not wet :(...  (Read 1849 times)
Offline dante
« on: Mon, 15 May 2017, 13:06:04 »
Has anyone thought about a dual/triple 30%-60% built like a Pipe Organ?
ie:
The idea is there are always compromises with embedded layouts.  Why not leave 30%-60% top layout as is and then put a second (or more) keyboard up on top/bottom for navigation , function keys , etc.
Why would you do this?
  • Keeps the keyboard width narrow.
  • No function key finger gymnastics: No forgetting what key does what.
  • Moar keys for MOAR artisans.
  • Such a case would allow for some Artistic work.
  • Make a compact set up as heavy or heavier than a fullsize.
What do you think?  Insane or Fabulous?
Re: I had a dream! And it was not wet :(...
« Reply #1 on: Mon, 15 May 2017, 13:11:19 »
Definitely insane.
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #2 on: Mon, 15 May 2017, 13:16:06 »
totally insane. do it!
« Reply #3 on: Mon, 15 May 2017, 13:19:17 »
well the reason the organ kind of get all these rows, is because of all the knobs and switches that have to fit within reach for the different organ voices.
For keyboard,  if everything already fits infront of you,  there's no real reason to layer it.
Offline ander
  • I type, therefore I am
« Reply #4 on: Mon, 15 May 2017, 18:03:34 »
Not entirely accurate. The multiple manuals (keyboards) are so you can set each of them to different registrations (combined sets of pipes) and play them simultaneously. Each pipe set is represented by a stop on the organ console. So the more manuals an organ has, the more stops it tends to have.
It's up to the organ builder to arrange the stops as conveniently as possible. But over a certain number of manuals, a console can be only so ergonomic—for an extreme example, the organ at the Boardwalk Hall Auditorium in Atlantic City, NJ:
I'm guessing that to reach those high stops, the organist must either have an assistant on a stepstool, or wait for a pause in the music and stand up on the bench.  :?)
Even if that were the reason, why not make a multi-level computer keyboard anyway—for the visual effect, if nothing else? I'd sure enjoy seeing one!
