Author Topic: Did I broke the switch of my mechanical keyboard?  (Read 2624 times)
Offline Dudayev
« on: Wed, 17 May 2017, 07:06:04 »
>Be me
>****posting on 4chan and using my cellphone
>Open pokemon go!
>Then, trying to catch a charmander spotted on my desk
>ButterFingers.webm
>Cellphone fall like a stone on my keyboard
>Shiiiiiiiiiet
>Check damage control
>Press Z and not be able to hear that delicious "click"
>But the key still working
Did I broke that switch? Exist any way to open that little **** to check it, but without rip the welding? Help.
Re: Did I broke the switch of my mechanical keyboard?
« Reply #1 on: Wed, 17 May 2017, 07:21:15 »
My head hurts after reading that.
But I'm thinking yes (you probably broke something) and no (you can't fix without replacing switch by desoldering and resoldering a new one).
Offline nmur
  • ಠ_ಠ
« Reply #2 on: Wed, 17 May 2017, 07:30:38 »
>>>/v/
« Reply #4 on: Wed, 21 June 2017, 22:17:41 »
If it's a clicky switch, maybe the clicky slider bit got stuck at the bottom.
Try repeatedly mashing the switch to see if it will loosen up a bit.
