Author Topic: How can I make my keyboard sturdier?  (Read 4427 times)
Offline manna
« on: Tue, 06 June 2017, 15:11:16 »
Hello everyone.
Simple (i hope) question: is there any way I can make my pcb mount keyboard more resistant without having to desolder all the switches and put a mounting plate on?
Perhaps placing a sheet of some material between the case and the pcb? Anyone tried something similar or have some suggestion? A custom acrylic case?
If it can help with the answer the pcb I'm talking about is a Leeku MX1800 L3.
Thanks.
Re: How can I make my keyboard sturdier?
« Reply #1 on: Tue, 06 June 2017, 15:22:39 »
Are you looking for a sturdier keyboard case or were you looking for a stiffer keystroke feeling?
If it's the first option you need to reinforce the case or add a plate (depending on how the pcb/plate mounts to the case). If it's option #2 you need to add a plate, people normally go PCB mount for a softer keystroke feeling because a PCB has more give than a metal or plastic plate does.
If you just have a PCB without any sort of case, adding a case will make the board stiffer and change the keystroke feeling a bit.
I hope that answers your question, I'm not totally sure what you're asking
Offline manna
« Reply #2 on: Tue, 06 June 2017, 16:22:37 »
Hey Joey.
I'm looking for a stiffer case, since I tend to bottom out and I'm afraid the PCB can get damaged in the long run because of all the flexing.
I actually already have a case, from an old G80-1800 which is compatible with the keyboard I'm using, but it's poorly made so it doesn't really help.
What I was thinking is getting a thin sheet of metal (1mm?) and placing it between the pcb and the bottom part of the case. This should help with the flexing, but I was wondering if it can damage the pcb somehow.
« Reply #3 on: Tue, 06 June 2017, 16:40:16 »
Adding a sheet of metal under the PCB won't do anything other than possibly short out components. The PCB shouldn't break because you're bottoming out unless you're hammering on it and trying to break something.
Offline merlin64
    • MechMerlin
« Reply #5 on: Tue, 06 June 2017, 16:48:30 »
I have the same PCB, the G80 1800 case is pretty flimsy and I would recommend you getting a Dolch PAC case...if you can get one.
In another case I've done the following:
1. Dynamat (same stuff used to dampen vibrations in cars)
2. Drawer Liner to go over the Dynamat
This has yielded a much more flex resistant keyboard and has also dampened some of the noise associated with it.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #6 on: Tue, 06 June 2017, 16:53:16 »
Make everything out of steel.
Offline Tactile
« Reply #7 on: Tue, 06 June 2017, 17:31:33 »
I put a sheet of rubber under the PCB on my PCB mount board.
REΛLFORCE
Offline SpectreiiI
  • Scribe
« Reply #8 on: Tue, 06 June 2017, 18:07:02 »
I have a Dolch PAC 65 G80-1813 that I wouldon't be willing to let go of.
Offline manna
« Reply #9 on: Tue, 06 June 2017, 18:15:08 »
How thick are the Dynamat and the drawer liner?
Offline merlin64
    • MechMerlin
« Reply #10 on: Tue, 06 June 2017, 18:15:39 »
If Manna just wants the case, I wouldn't mind splitting the cost and just getting the PCB and the LED PCB
Offline merlin64
    • MechMerlin
« Reply #11 on: Tue, 06 June 2017, 18:16:33 »
You'd have to look on their website I don't quite remember: http://www.dynamat.com/
Drawer Liner I think is dependent on which store you go to.
Offline SBJ
  • Tactile pls
« Reply #12 on: Tue, 06 June 2017, 23:36:57 »
ALL the steel!
« Reply #13 on: Wed, 07 June 2017, 04:30:29 »
Ditto on Dolch case, but be prepared that the Dolch has a flat case where as the original G80-1800 is quite inclined.
I have seen a group buy for a metal case but I think it required a metal plate.
Offline chyros
  • a.k.a. Thomas
« Reply #14 on: Wed, 07 June 2017, 04:50:47 »
ALL the steel!
Exactly. Down the line I'll be showing you guys a proper keyboard. And I mean PROPA proper.
Offline manna
« Reply #15 on: Wed, 07 June 2017, 15:02:07 »
I'm not sure I could afford a Dolch case, so if you get the keyboard you can keep it.
Offline SBJ
  • Tactile pls
« Reply #16 on: Thu, 08 June 2017, 07:40:38 »
ALL the steel!
You just made my mouth water. I'll be looking forward to it!
Offline chyros
  • a.k.a. Thomas
« Reply #17 on: Thu, 08 June 2017, 08:28:07 »
ALL the steel!
You'll like it, I guarantee it ;) .
