Author Topic: Where to get Cherry MX Clears?  (Read 4622 times)
Offline Vox
« on: Sat, 10 June 2017, 22:01:28 »
Hello! I am working on making my first keyboard using the Sentraq S60-X kit. I want to get cherry mx clears and use tactile greys for the spacebar and a couple other keys but I am having trouble finding a place that has clears in stock. Does anyone here know of anyplace that has them? Thanks!
Offline ideus
  • Björkö.
Re: Where to get Cherry MX Clears?
« Reply #1 on: Sat, 10 June 2017, 22:35:49 »
You can get them here, a bit expensive, but it is a store with good track record and has them in stock.
There are other sources like the classifieds and overseas vendors, but you will need to do your own research and run with some risks.
« Reply #2 on: Sat, 10 June 2017, 22:43:53 »
Those are out of stock.
They aren't that expensive though so long as you buy at least 100. :D
Offline ideus
  • Björkö.
« Reply #3 on: Sat, 10 June 2017, 22:50:43 »
Are they? oh sorry then.
Offline Vox
« Reply #4 on: Sat, 10 June 2017, 23:19:48 »
yeah, as I said. I can't find them anywhere. I think I might have to settle on a different switch. Any suggestions on something similar?
Offline Vox
« Reply #5 on: Sat, 10 June 2017, 23:23:47 »
I found them on DigiKey. Anyone have any experience with them? I'm not questioning their legitimacy but Customer Support and shipping time is unknown.
https://www.digikey.com/products/en?wt.z_cid=ref_Mectronic&site=us&keywords=MX1A-C1NW
Offline Singular
« Reply #6 on: Sun, 11 June 2017, 01:10:50 »
Switchtop still has some in stock.
http://www.switchtop.com/product/cherry-mx-switches
« Reply #7 on: Sun, 11 June 2017, 01:33:01 »
digikey is legit
never ordered anything but heard good things
Offline ddot
  • Master of Suspense
« Reply #8 on: Sun, 11 June 2017, 02:27:40 »
Do they need to be new?  heroinbob used to sell harvested cherry switches.  You could check with him to see what he has in stock at the moment
https://geekhack.org/index.php?topic=76543.msg2405088
Offline jalaj
« Reply #9 on: Sun, 11 June 2017, 12:54:39 »
No response to my PM.
So I'll try here. I have new, unused MX clears.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Offline Vox
« Reply #11 on: Sun, 11 June 2017, 15:57:48 »
oh sorry. I only come onto this forum once or twice a day. responding...
Offline Vox
« Reply #12 on: Sun, 11 June 2017, 16:08:23 »
Thanks for the suggestion. I'll ask him.
https://1upkeyboards.com/cherry-mx-switches.html
Thanks. I'll probably default to them if I don't get the switches anywhere else
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #13 on: Sun, 11 June 2017, 16:44:44 »
Yep, skiwithpete also live streams new product demos. I've never met the guy but he legitimately seems to be a decent dude
