Author Topic: You're listening to white noise.  (Read 4440 times)
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« on: Fri, 16 June 2017, 13:15:26 »
Or aren't you? I'm referring of course to Dave Clarke's outstanding techno/electro radio show on RTE FM. Download podcasts here: http://www.rte.ie/2fm/white-noise/
I've been listening since 2011 and I was wondering if there are other techno/electro fans out there that also listen to it :) .
Re: You're listening to white noise.
« Reply #1 on: Fri, 16 June 2017, 13:19:01 »
I have been listening to a high-pitched hiss since a Depeche Mode concert in 2006.
Offline scwoopz
« Reply #2 on: Fri, 16 June 2017, 13:39:43 »
you, sir, have tinnitus.
ortho or shmortho
Offline Sniping
« Reply #3 on: Fri, 16 June 2017, 18:32:49 »
^ lmao
« Reply #4 on: Fri, 16 June 2017, 19:26:26 »
hahahahahahahahahahahahahhahahahahahaha
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #5 on: Sat, 17 June 2017, 05:56:51 »
I have to listen to white noise all day at work with a load of huge aircon units running behind me 24.7...
« Reply #6 on: Sat, 17 June 2017, 08:12:35 »
/LifeMethlab
Offline dante
« Reply #7 on: Sat, 17 June 2017, 15:13:57 »
In my teens I'd listen to Erasure, Front 242, and early Ministry (at their best IMHO) and was happy with that - but the golden years for Electronic music was between 1999-2003.
Yes there is good music still being put out but in those few years the quality was highly concentrated.
Offline ANightOnCloudNine
« Reply #8 on: Sat, 17 June 2017, 18:45:42 »
white noise? like country, metal, punk and electronic?
Offline Otesanek
« Reply #9 on: Sun, 18 June 2017, 18:03:48 »
I can't sleep without it
Offline Altis
« Reply #10 on: Sun, 18 June 2017, 19:01:21 »
I always took you for a SomaFM guy.  :cool:
Offline chyros
  • a.k.a. Thomas
« Reply #11 on: Mon, 19 June 2017, 00:38:14 »
What are that? XD
Offline killiah
« Reply #12 on: Mon, 19 June 2017, 04:08:45 »
i like noises, hahha
Offline zombimuncha
« Reply #13 on: Mon, 19 June 2017, 05:17:35 »
I have a background-noise type app that I use with isolating earphones to block out the distracting chatter at the office. The air-con noise is the best one.
« Reply #14 on: Mon, 19 June 2017, 22:23:13 »
Are you sure that's not Justin something taking over the air waves?
Offline Altis
« Reply #15 on: Wed, 21 June 2017, 12:35:49 »
What are that? XD
Internet radio that's been around forever. They have a bunch of stations, most notably "Groove Salad".
Nothing like bit of SomaFM and some vintage keyboarding.  :cool:
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #16 on: Thu, 22 June 2017, 16:42:12 »
Sometimes, the shop fan plays Fury Of The Storm. Shop fan is haunted. Please send help
Offline ander
  • I type, therefore I am
« Reply #17 on: Fri, 07 July 2017, 17:22:36 »
Frankly, we were doing stuff like that back in the '80s with Moog synthesizers, where you connected the modules with phono cables.
The hardware's progressed, but esthetically it seems as though musicians still have a lot in common with switchboard operators.
