Author Topic: Gateway Drug ??  (Read 3482 times)
Gateway Drug ??
« on: Mon, 19 June 2017, 11:47:52 »
UPDATE:
Does anyone know what kind of accuracy and precision would constitute (Not Suck) using a $30 cheapie such as this ?
Currently with only highschool gym archery xperience, am shooting 5 inch diameter groups at 15 meters in the basement..
Yea i sux...
But heck, for $30, at least I haven't put any holes in the wall..
Plan to use in Basement..   only $29.99 off the ebay
3 weeks later, I won't be buying any $400 contraptions will I   ?? .. !!
Offline Coreda
Re: Gateway Drug ??
« Reply #1 on: Mon, 19 June 2017, 12:04:27 »
Tried to reverse image search and first result sounds like some have horrific QC. Hope you got a good one.
Do not buy!!!!!! I assembled as per instructions. I set up target aimed fired and cheap plastic thing holding 80 lb string exploded string whipped around hit me in the face causing a whelp on my eye area could have put my eye out but had a shiner for about 5 days.
I have now bought two of these. Both of which broke on the first use. On the first one the bolt stabilizer broke off on the first shot. The second one's end caps just shattered on the first shot and therefore caused that bolt to break and flung in a different direction than was aimed. Could have been dangerous.
Re: Gateway Drug ??
« Reply #2 on: Mon, 19 June 2017, 12:12:44 »
Pretttty sure that's to be expected for $30..  hahahahaha
Offline drewba
Re: Gateway Drug ??
« Reply #3 on: Mon, 19 June 2017, 14:22:48 »
Depends on you, but I would be if that was something I was interested in. I never got in to archery but I did spend all of my money in my late teens-early twenties on paintball. There is a massive difference between a $200 gun and a $700 gun. Then another massive difference between a $700 gun and a $1200 gun. If you start competing, RIP UR WALLET.
Offline dgneo
  • Supervillain
Re: Gateway Drug ??
« Reply #4 on: Mon, 19 June 2017, 14:26:43 »
Becoming Vegan,
Questioning just how much internet is too much internet,
Buying a crossbow,
TP4 what r u trying to tell us
Re: Gateway Drug ??
« Reply #5 on: Mon, 19 June 2017, 14:57:31 »
Becoming Vegan,
Buying a crossbow,
Neo-Era Mid-life Crysis.. !! ??
Re: Gateway Drug ??
« Reply #6 on: Sat, 24 June 2017, 18:59:06 »
Yea i sux...
Re: Gateway Drug ??
« Reply #7 on: Sat, 24 June 2017, 19:45:49 »
Does anyone know what would constitute (Not Suck) using a $30 cheapie such as this ?
Currently only am 5 inch diameter at 15 meters in the basement..
Yea i sux...
if you read this out of context it's about a man with a 15 meter **** whipping it around in his basement looking for a $30 hooker
Re: Gateway Drug ??
« Reply #8 on: Sat, 24 June 2017, 20:13:53 »
Noisy,  you're projecting..   it's just you man... hahahahahahhahahaa
Re: Gateway Drug ??
« Reply #9 on: Tue, 27 June 2017, 12:47:42 »
Welp!!  already broke the serving on the string..
I just put some thick clear tape on it,  seems to work just fine..
Offline futurecrime
  • Get Zooted
Re: Gateway Drug ??
« Reply #10 on: Thu, 29 June 2017, 05:53:47 »
Sounds like it's fine. Wear goggles.
Offline ander
  • I type, therefore I am
Re: Gateway Drug ??
« Reply #11 on: Fri, 07 July 2017, 16:42:21 »
Must it be a crossbow, though? Why not a happybow?
