Author Topic: DIY: Negative tilt on Matias Ergo Pro without the armrests?  (Read 5210 times)
Offline wizonesolutions
    • FillPDF Service
« on: Fri, 30 June 2017, 05:15:42 »
I removed my MEP's palm rests because I have a MouseTrapper Advance+, and it has palm rests built in.
I would still like to achieve negative tilt, though. I've heard this might be possible through the 1/4" screw holes. Wondering if anyone has done this and what they used. A key goal is that it only tilts the keyboard and doesn't make the whole thing sit higher, or at least not much higher.
I have a sit-stand desk, and I want to stand with my arms at 45˚ instead of 90-ish˚...but that is not very comfortable without some tilt.
Re: DIY: Negative tilt on Matias Ergo Pro without the armrests?
« Reply #1 on: Fri, 30 June 2017, 08:35:22 »
take a picture of your desk with your desired (Hand position).
Your description is not very clear as to what it is you're trying to position into.
