Author Topic: Bug collection ?  (Read 1736 times)
Bug collection ?
« on: Sun, 02 July 2017, 23:37:22 »
Anyone got one ?
How does this work,  do you start by catching,  collecting local bugs ? or is this mostly an ebay thing.
Re: Bug collection ?
« Reply #1 on: Sun, 02 July 2017, 23:38:38 »
is it considered cruel ?
Offline nmur
  • ಠ_ಠ
« Reply #2 on: Sun, 02 July 2017, 23:45:46 »
live or dead?
in museums and such i've seen some pretty cool bug displays, and they all look perfectly preserved with a fine pin through their middles
Offline futurecrime
  • Get Zooted
« Reply #3 on: Mon, 03 July 2017, 05:51:17 »
You will need a very small crossbow to hunt bugs.
« Reply #4 on: Mon, 03 July 2017, 07:41:59 »
Use a net to catch things like butterflies or something like a plastic cup and a piece of cardboard for smaller ones. If you aren't squeamish bare hands are often easiest. You can also put bait in a cup laid on its side and wait for them to enter.
For killing, a glass jar with a tight lid and an alcohol-soaked pad in the bottom will provide a final high and a quick end, then lay them out flat so that they dry and stiffen in an attractive configuration.
- Franklin Roosevelt 1933
« Reply #5 on: Mon, 03 July 2017, 07:44:43 »
Check out the guy who made Pokemon.
