Author Topic: Unicomp Ultra Classic not working.  (Read 2716 times)
Offline Deverica Wolf
  • My name is Hack, Geek Hack.
    • Head-Fi
« on: Tue, 04 July 2017, 14:25:04 »
I purchased around 2011, and used it on and off. I used it last around a year ago. I plugged it in, but it's not working at all. Windows 7 says it installed correctly, but there is no response, and the 8 light ls stuck on. I tried different USB slots, and even plugged it into a PS2 converter; nothing. All my other keyboards are working fine. It didn't fall or get wet so I think it's a driver issue. Any tips are appreciated. Thanks.
UNICOMP.Spacesaver BS  |  FILCO Majestouch-2 TKL  |  FILCO Majestouch-2  [-_-]~ TKL  |  FILCO Majestouch-2 TKL
FILCO Majestouch-2 TKL  |  Deck Legend - ToXic  |  CHERRY∵ Touchboard ITA
Offline 1391406
Re: Unicomp Ultra Classic not working.
« Reply #1 on: Tue, 04 July 2017, 21:12:24 »
Have you tried it on another PC?
« Reply #2 on: Tue, 04 July 2017, 21:42:16 »
If you tried a PS/2 convertor, you would need to turn the PC off, plug the keyboard in, then turn the PC back on for it to register.  PS/2 is not hot-pluggable.
« Reply #3 on: Tue, 04 July 2017, 22:06:01 »
probably bad cable..
take it apart check the cabling with a multimeter.
