Author Topic: What is UV Coating on Cooler Master Masterkeys pro?  (Read 3098 times)
Offline dman777
« on: Sat, 08 July 2017, 00:18:22 »
I'm confused by what the UV coating is on the Cooler Master Masterkeys pro keyboards. Some have stated it gets dirty easy and don't like it. But isn't it just some chemical that keeps the plastic from fading? Isn't it non detectable on a plastic surface like it is on sun glasses?
Re: What is UV Coating on Cooler Master Masterkeys pro?
« Reply #1 on: Sat, 08 July 2017, 00:23:40 »
so if you leave a keyboard in the sun.
the ultraviolet rays can damage the plastic,  either the paint coating OR the plastic itself.
So a uv coating would improve the durability of the keycap paint/ plastic to some extent.
HOWEVER,  all painted back lit keys get rubbed off eventually.   And if you're one of those kids that never cut their nails, it will happen quite soon.
There exists double shot back lit keycaps you can replace the original with,  but it's like another 80 bux,
Backlit overall is on the tacky side,  but kids love um..
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #2 on: Sat, 08 July 2017, 02:11:57 »
Actually, it appears they are referring to the printing method.
Offline dman777
« Reply #3 on: Sat, 08 July 2017, 02:26:25 »
The UV coating is actually on the frame. But supposedly the frame gets dirty easily because of it. Not sure why, that is why I was asking what it is exactly.
« Reply #4 on: Sat, 08 July 2017, 10:45:13 »
If that's the case,  then it's completely useless. and they're just fukin with you.
it's a black keyboard,  uv turns plastic yellow,  you won't even see that over black..
« Reply #5 on: Sat, 08 July 2017, 10:56:45 »
They need to fire their marketing guy..   I bet it's the same guy who suggested they use those slutty looking girls with tacky makeup in their old promo videos.
hahahaha
Cringe worthy things they wrote about their own keyboard.
= Built for Pros not Joes
= Idiot-Proof
= For those who want to go pro, not for those who want to look pro
= S-tier performance
Ok.. Who's joe, and why did they need to alienate everyone named joe. Even if this is a common idiomatic expression, it's unnecessarily antagonistic.
Idiot proof,   ok, when you write that,  it implies a portion of your customers are idiots,   why would you say that.. probably because their marketing guy is an idiot. hahahaha
Go Pro , not Look Pro,    really?   so a pro wouldn't also look pro,  a pro has to look like something OTHER than the PRO that he is ?
__ Jesus christ,
S- Tier performance..  /// Facepalm..   It's ok to insert superlatives,  but S-tier is only relevant if there is an actual Tier list in play..
-- For example if you had sports, and you mention gold medals..
--  What is s-tier in this case, it is completely meaningless..
Coolermaster should be ashamed of themselves..  hahahahaha,  They've continued to redefine Crass advertising..
Sigh...  is this the problem with public education ? either way.. /head shake..
Offline chyros
  • a.k.a. Thomas
« Reply #6 on: Sat, 08 July 2017, 12:05:41 »
They used it to colour the case then? Bit weird if you ask me.
« Reply #7 on: Sat, 08 July 2017, 12:18:26 »
Well, i read somewhere that uv reflecting paint makes colors pop more,  because even though it's not in the visible spectrum, your receptors still get a larger burst of energy ?
Something like that..
Offline chyros
  • a.k.a. Thomas
« Reply #8 on: Sat, 08 July 2017, 12:36:00 »
That sounds weird. How would they be influenced by wavelengths that they don't respond to? Oo
« Reply #9 on: Sat, 08 July 2017, 13:53:12 »
Well astronauts see spots of light due to gamma radiation even when they have their eyes closed in space..  and gamma isn't in the visible spectrum either..
So I'd assume it's a similar process.
