Author Topic: [Help]Adding leds to Poker3{Solved}  (Read 1573 times)
Offline Lemma998
« on: Thu, 27 July 2017, 19:27:48 »
Hi all,
I really need your help.
I have a poker3. I hope to add backlight to my keyboard. And I bought 100pcs 2x3x4 white led (20mA).
Now I solder some of them to PCB and test it. I found I can not light up those LEDs.
Is there anyone can help me? I really appreciate.
« Last Edit: Fri, 28 July 2017, 10:00:22 by Lemma998 »
Poker3 brown switches, Ducky 2087s blue switches.
Offline Lemma998
Re: [Help]Adding leds to Poker3{Solved}
« Reply #1 on: Fri, 28 July 2017, 10:05:16 »
This is a tragedy. This is a disaster. When I soldered all, I realized that I made a mistake. Anode and Cathode are exchanged. I think Poker3 PCB PCB mark is misleading. I should solder the cathode of led to the positive mark "+" on PCB.
Sad  :'( :'( :'( :'( :'( :'( :'( :'( :'(
Online tp4tissue
« Reply #2 on: Fri, 28 July 2017, 10:17:26 »
well u can cut the traces where they begin,  and flip it with copper wires,
this might be less work than desoldering all of them and resoldering.
