Author Topic: Best duster?  (Read 4851 times)
Offline AlexG
Best duster?
« on: Sat, 29 July 2017, 11:03:46 »
Are there any unlimited use air dusters out there that are better than the usual compressed can? I know the hurricane thing that Massdrop tries to sell is awful. I'm okay with there being a cord.
Re: Best duster?
« Reply #1 on: Sat, 29 July 2017, 11:17:25 »
Dude I've searched HIGH and LOW.. for this..
Eventually,  I figured it out..
You just take your Hitachi Leaf Blower..  a whole REAL 1.13 gasoline horsepower..
It works SUPER good cleaning my pc..    p00fff all clean
Those electric ones total wimpy.. datavac blower nonsense,
u can't beat gasoline..
It even smells Manly.. !!
Hitachi leaf blower For Manly PCs,
Datavac is for girly pcs..
174506-0
Offline devoi
Re: Best duster?
« Reply #2 on: Sat, 29 July 2017, 11:54:21 »
Go with something by datavac.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Best duster?
« Reply #3 on: Sat, 29 July 2017, 19:03:53 »
I use a little snot sucker bulb but all entry points on my PC have dust filters so it's not much of an issue. I guess there are variants of air compressors with filtration systems to help eliminate moisture and static discharge but at that price point--I'd wonder if buying something from Metrovac/Metro Vacuum (Datavac) would make more sense.
Offline AlexG
Re: Best duster?
« Reply #4 on: Sat, 29 July 2017, 21:14:40 »
I'm not really worried about cleaning my PC. I hardly ever have to dust the inside, I figured out the golden ratio for negative air pressure. Mainly just keep my keyboard clean.
Re: Best duster?
« Reply #5 on: Sat, 29 July 2017, 22:52:30 »
DataVac is all you need my man.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Best duster?
« Reply #6 on: Sat, 29 July 2017, 23:31:24 »
Oh damn keyboard cleaning. I use hot soapy water for the keys and one of them thin brushes that came with my clipper set for the non-washables. Because I'm lazy like that
Offline SBJ
  • Tactile pls
Re: Best duster?
« Reply #7 on: Sat, 29 July 2017, 23:32:26 »
I basically do this. Except I've got a toothbrush for all the scrubbing. :p
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Best duster?
« Reply #8 on: Sat, 29 July 2017, 23:39:23 »
Forgot to mention the toothbrush for scrubbing the caps :-[ I use the thin brush to brush out all the hair from the key channels haha
Re: Best duster?
« Reply #9 on: Sun, 30 July 2017, 00:42:03 »
Datavac is too wimpy..
Hitachi Leaf blower , m0ar power.. !!!
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Best duster?
« Reply #10 on: Sun, 30 July 2017, 01:14:08 »
*Radio Edit*
« Last Edit: Mon, 01 August 2022, 07:11:59 by xtrafrood »
Offline iri
Re: Best duster?
« Reply #11 on: Mon, 31 July 2017, 17:14:03 »
wow people clean their keyboards
-Ray Bradbury
Offline JP
Re: Best duster?
« Reply #12 on: Fri, 04 August 2017, 13:45:56 »
I use this to blow out my computers at home and at work. Have not bought a can of air since.
https://www.amazon.com/Metro-ED500-DataVac-500-Watt-Electric/dp/B001J4ZOAW
There is a higher end model I like even better that is marketed to the pet grooming market (dogs hates these though as they are so loud). I scored a new one at a yard sale for $5. This model is 1.3 HP Vs. 0.75 HP for the standard ED500 model.
https://www.bedbathandbeyond.com/store/product/metrovac-reg-air-force-reg-quick-draw-compact-portable-pet-dryer/1018267446?skuId=18267446&mcid=PS_googlepla_nonbrand_cleaning_online&product_id=18267446&adtype=pla&product_channel=online&adpos=1o10&creative=43742633029&device=c&matchtype=&network=s&gclid=Cj0KCQjwtpDMBRC4ARIsADhz5O5L-hOw3fEoX8eK3p5q75RPSVHZXNuP3EjLdC-mjnpY9Cm5boixgnAaAtXGEALw_wcB
This also works great for drying freshly washed key caps.
« Last Edit: Fri, 04 August 2017, 13:49:00 by JP »
About Me | The Collection
Re: Best duster?
« Reply #13 on: Fri, 04 August 2017, 15:49:46 »
nm.. checked it, it should be legit.
Offline JP
Re: Best duster?
« Reply #15 on: Fri, 04 August 2017, 20:19:20 »
Yea, way overkill. If you still need more power you would be better off with a heavy duty air compressor.
