Author Topic: Wire diameter for Hand-Soldering Teensy proj.  (Read 2596 times)
Offline OhManIAmWorried
« on: Sat, 05 August 2017, 15:25:55 »
I have a roll of 2mm in diameter single-core wire (without resin). The plan is to use for teensy board for columns.
A guide that I read suggested to use 1mm wire or less, so I am wondering, should I search for another wire or this will do just fine.
Quite ashamed of not knowing the answer myself, please help :D
APC F-21 "Clicker" Drevo71 Delux M-618 DataComp dfk102
NTC 74% cut
Online Findecanor
Re: Wire diameter for Hand-Soldering Teensy proj.
« Reply #1 on: Sat, 05 August 2017, 15:34:08 »
"Without resin"? You mean solder?
« Reply #2 on: Sat, 05 August 2017, 15:56:32 »
If it fits through the hole it should be OK.
- D Trump 2026-10-24
« Reply #3 on: Sat, 05 August 2017, 16:25:25 »
I couldn't remember the word in Engrish. I mean that 2mm is the diameter without insulation.
Don't understand the point of hole fitting. The thing that I am asking about is will this matrix even work with the wire that thick (will the current be enough, and if the thickness is that important).
« Last Edit: Sat, 05 August 2017, 16:27:44 by OhManIAmWorried »
NTC 74% cut
« Reply #4 on: Sun, 06 August 2017, 00:03:16 »
pretty much anything works unless you got some sort of sustained load.
Offline ErgoMacros
« Reply #5 on: Sun, 06 August 2017, 02:39:30 »
Hi,
The stuff that turns liquid, melts, because you heat is called is "solder." When it cools it gets hard again.
Solder either has resin in the center (resin core), or not (solid). Generally I think resin core is better for hand wiring a keyboard.
Solder joins other metal parts together.
"Wire" is the stuff that never melts... it stays strong and bendable. Wire carries the electricity from place to place. Wire does not have resin.
So, it sounds like you are asking about "wire." Thick wire is used for lots of electricity. Keyboards do not need lots of electricity.
For a teensy 19ga to 22ga will probably do fine. (0.91mm to 0.64mm) 2mm seems thick to me for Teensy and keyboards.
Hope that helps.
Today's quote: '...“but then the customer successfully broke that.”
« Reply #6 on: Sun, 06 August 2017, 10:13:05 »
My guess would be that 24ga to 28ga would still be fine.
USB standard is 0.5A at 5V DC.
Online Findecanor
« Reply #7 on: Sun, 06 August 2017, 11:57:42 »
I would use insulated wire, and in different colours if I could get it to make it easier to see what is what.
