Author Topic: It's slightly Askew  (Read 3045 times)
It's slightly Askew
« on: Sat, 19 August 2017, 13:26:13 »
Bought a Cheapee..
Would you take it off and glue it back on ?
176370-1
Re: It's slightly Askew
« Reply #1 on: Sat, 19 August 2017, 14:37:19 »
What is wrong in this ridiculously oversized blurry4032×3024 pixel picture?
Offline mrhead
  • Thread \ (•◡•) / Stopper
« Reply #2 on: Sat, 19 August 2017, 15:49:54 »
The heatsink is not parallel to the circuit board.  Is it making good contact with the chip?
« Reply #3 on: Sat, 19 August 2017, 16:56:52 »
As long as it isn't making contact with any leads or solder bubble, it should be fine, right?
Offline fanpeople
« Reply #4 on: Sat, 19 August 2017, 16:59:43 »
u need to buy a noctua cooler for it abd mod it to fit. its the only way
« Reply #5 on: Sat, 19 August 2017, 20:41:11 »
that's impossible,   the chip is too close to the pcie,
I would have to use a ribbon cable ..  if i wanted to bolt-mod a cooler.
« Reply #6 on: Sat, 19 August 2017, 20:43:20 »
well it's anodized, so technically as long as there isn't PRESSURE against any components,   it shouldn't cut through the anodized layer to become conductive..
HOwever..  still triggered. !!
Offline fanpeople
« Reply #7 on: Sat, 19 August 2017, 20:44:13 »
horses say neigh, men say can be done
« Reply #8 on: Sat, 19 August 2017, 22:28:38 »
Lies..
Tp4,  xpert camera fone user..
Offline pingmaster
« Reply #9 on: Sun, 20 August 2017, 09:34:57 »
Lies..
Plz use A31p webcam next time for maximum retroness. TP 850 PPC Webcam for style points.
