Author Topic: EX2: Ergonomic Split Mechanical Keyboard  (Read 9174 times)
Offline patosai
« on: Fri, 08 September 2017, 10:20:59 »
Hey everyone. First post here.
I worked on this during the summer and some of my friends were interested, so I made a bunch of them. First, the pics.
Here is the completed product!
177795-0
A side shot.
177797-1
The mini-USB connector.
177799-2
And now for the build log!
The PCBs in their casing from the manufacturer. I got these made in Korea by Quickturn PCB. Quality is great and they're fast! Arrived in the US about 7 days after I ordered them.
177801-3
Meanwhile, prototyping the case with a Makerbot. Seems to fit together well, the top and bottom halves are held together by various protrusions on the outside of the top that 'clip' around the bottom half.
177803-4
Here the PCB is inside the case; the case was a little too small though, forgot to add some extra space to the outside. Fixed that in later prints though.
177805-5
Soldering the very first one! Started around midnight, finished around 5AM...
177807-6
Soldered the home row switches on
177809-7
Now all the switches are soldered on
177811-8
Keycaps all on! I designed the spacing so a regular 87-keycap set would work. I like the blank keys, as you can see.
177813-9
And that's a wrap!
I wrote the firmware for the one you see here, but it should be simple to use QMK or TMK if you want, I'm using the same micro as them (ATMega32U4).
I have some extras to sell, if you are interested please let me know! I have blue and brown switches.
« Last Edit: Fri, 08 September 2017, 10:24:08 by patosai »
Offline algernon
  • A tiny mouse, a hacker.
    • Diaries of a Madman
Re: EX2: Ergonomic Split Mechanical Keyboard
« Reply #1 on: Fri, 08 September 2017, 10:44:50 »
Out of curiosity, is your firmware open source?
Offline patosai
« Reply #2 on: Fri, 08 September 2017, 11:02:32 »
Yep, it's here:
https://github.com/patosai/ex2
The build Makefile is still a little messy, I'm going to be cleaning that up soon.
Offline patosai
« Reply #4 on: Fri, 08 September 2017, 17:14:04 »
The holes are on the PCB for a stabilizer, but I didn't notice a major difference with or without. The one shown doesn't have the stabilizer.
Offline kurplop
  • THE HERO WE DON'T DESERVE
« Reply #5 on: Fri, 08 September 2017, 17:32:35 »
Good job. At first glance, it looks like an improvement in the thumb key placement over the ErgoDox.
Offline lordgiblite
« Reply #6 on: Fri, 08 September 2017, 20:50:43 »
Looks more comfortable than an ErgoDox to me, haven't tried one but this one makes me want to try!
Offline yoippari
« Reply #7 on: Sat, 09 September 2017, 00:31:15 »
So the right is the slave and only has the micro usb. The left side has the micro from the computer, one usb A as out to the slave, what is the second USB A?
Offline patosai
« Reply #8 on: Sat, 09 September 2017, 00:53:16 »
One of my friends has the Ergodox EZ and I tried it out. I thought the thumb positioning was too far out so when I made this I made sure to move it a little closer.
There's two USB As because that's supposed to be a USB hub. The two halves are completely separate and can be plugged into the computer separately.
The dream:
  - connect one half to the other
  - connect the other half to the computer
  - free USB ports on the other half for other uses (mouse, phone, etc)
But the USB hub hasn't been cooperating... so there's no USB hub for now.
« Last Edit: Sat, 09 September 2017, 00:55:42 by patosai »
« Reply #9 on: Sat, 09 September 2017, 09:26:54 »
The dream:
what's your tenting solution for this board..
Offline patosai
« Reply #10 on: Sat, 09 September 2017, 11:14:00 »
No solution yet. I like the Ergodox EZ solution but I'm wondering how to get it to tent more.
« Reply #11 on: Sat, 09 September 2017, 12:00:21 »
ergodox ez's system takes up the middle space between the keyboards,  that space is useful for mousing..
A couple holes drilled around the edges of the bottom face plate is best and most flexible.
I use 150mm screws for tenting on OG ergodox.
