Author Topic: Bought a desoldering station  (Read 4779 times)
Offline pixelpusher
« on: Thu, 21 September 2017, 11:02:36 »
I told myself the boards were getting out of hand, so I didn't need that camp225.  Spent $300 on a desoldering station... makes sense to me  :thumb:
Offline pixelpusher
Re: Bought a desoldering station
« Reply #1 on: Thu, 21 September 2017, 11:03:36 »
On the bright side, now I can get those horrible horrible silent red switches out of my Filco even faster.
« Reply #2 on: Thu, 21 September 2017, 11:11:25 »
You can ship them to me if they are that bad, I'll take care of them.
PS: What did you get?? Need more details....also....this would really fit better in the making things subforum. :p
PPS: I've heard filco solder can be a nightmare to remove so be prepared and don't overheat the pcb.
Offline pixelpusher
« Reply #3 on: Thu, 21 September 2017, 11:22:25 »
I got the Hakko FR300 gun with the kit (stand, cleaning tools, and case)
We'll see on the Filco.  It's probably like my CM boards.  I think they use lead-free solder or something.  It's always sticky and blobby.  I've added flux in the past to help it flow, but I always get the best results from adding a touch of rosin core solder on it.  Probably just need to invest in better flux :)
The reds are so bad.  I can't imagine anyone would want them.  Super scratchy.  I suppose I could break down and lube them.  I've avoided lubing switches for 3 years now.   :p
« Reply #4 on: Thu, 21 September 2017, 11:23:51 »
My 2 leopolds with silent reds are wonderful.... :o
And nice desoldering gun I've got the hakko 808 model.
« Reply #5 on: Thu, 21 September 2017, 11:40:59 »
Now you're obligated to help other gekhkrs desolder stuff..
Prepare for influx of kybord related mail..
Offline pixelpusher
« Reply #6 on: Thu, 21 September 2017, 12:32:15 »
« Reply #7 on: Thu, 21 September 2017, 12:33:12 »
Too late.. You've been outted.. hahahahahha
Offline typo
« Reply #8 on: Thu, 21 September 2017, 22:37:24 »
Yes, be very careful not to overheat it. You will run into big problems. I use a pretty low temp and take my time. I had just said elsewhere my Grandson whom is an EE with very high end equipment can desolder a 105-8 board in 25 minutes. Took me like 2-1/2 hours. This is why people will be sending them to you lol. Old decks are horrible. The solder goes right through the hole onto the front. Just be careful.
Offline pixelpusher
« Reply #9 on: Thu, 21 September 2017, 22:39:03 »
Noted.  I have desoldered two TKLs and a 60% just with a pen pump, so I have some experience.  Solder through the hole is the worst.  Hoping that won't be as much of an issue with this new equipment.
Offline pixelpusher
« Reply #10 on: Sun, 24 September 2017, 13:54:55 »
Well, I have to wait until Tuesday now.  The gun came with a 1mm tip.  Not really big enough for anything.  Ordered a 1.6mm tip.
Offline pixelpusher
« Reply #11 on: Tue, 26 September 2017, 12:13:31 »
The new tip came in.  1.6mm and it's perfect (well, you don't hear that every day). I got 10 switches out in roughly 45 seconds.  Amazeballs invention.   I'll have to see if that 1mm tip will work on LEDs.  Gotta go find some more stuff to desolder!
« Last Edit: Tue, 26 September 2017, 12:30:05 by reececonrad »
« Reply #12 on: Tue, 26 September 2017, 12:30:47 »
that's what she said.. !!!!!!!
Offline AuthenticDanger
« Reply #13 on: Tue, 26 September 2017, 12:42:05 »
What's your address? I have 4 or 5 prototype boards I need the switches reclaimed from.
Thanks for volunteering to do this for the community!
F Keys belong on the left.
« Reply #14 on: Tue, 26 September 2017, 15:14:42 »
 reececonrad, what a great guy.. !!
Offline xondat
  • i'm not a star
« Reply #15 on: Tue, 26 September 2017, 15:20:22 »
I have a few boards that need desoldering too :))
Great guy!
Offline pixelpusher
« Reply #16 on: Tue, 26 September 2017, 15:41:12 »
ABORT!!  ABORT!!!  How do I delete a thread!?  AAAAAAAAHHHH    :p
Offline Tiramisuu
« Reply #17 on: Tue, 26 September 2017, 15:51:32 »
I have a couple of boards here that could use desoldering as well  :p
My solder sucker arrived last week but somehow it just isn't the same.
Keyboard error F1 to continue.
Poker 2, Gherkin, Lets Split, Planck, Filco
« Reply #18 on: Tue, 26 September 2017, 16:10:31 »
On a serious note, I'm super jealous. I'm going to spend a few hours desoldering boards, but this would be amazing. Just not sure if I should drop the $300 on one... how much is my time worth... hmmm...
I'm curious to hear how much you like the gun. Maybe I will just bite the bullet and get one. Desoldering switches from prototype boards would save me money on new switches.
Offline pixelpusher
« Reply #19 on: Tue, 26 September 2017, 16:29:38 »
I'll get back to you after I do an entire TKL.  I should have a better idea of how much I like it or not by then.
« Reply #20 on: Tue, 26 September 2017, 16:41:45 »
That'd be great. I have 4 or 5 TKL-sized boards to get switches off, so saving a bunch of time would be awesome.
Offline eksuen
  • Ambassador of explosions.
« Reply #21 on: Tue, 26 September 2017, 16:42:31 »
A simple heated desoldering iron has worked for me. It does tend to get clogged after a while and more frequent cleaning is probably warranted, but when it's working, it works quite well. I'm able to desolder switches and LEDs with it.
https://smile.amazon.com/dp/B008DJRYIG/_encoding=UTF8?coliid=I2F617AJ54WBE0&colid=1QFVQCVPU20NS
Offline ander
  • I type, therefore I am
« Reply #22 on: Sun, 01 October 2017, 02:17:28 »
Do you need a separate soldering station to solder the stuff you've desoldered?
Offline pixelpusher
« Reply #23 on: Sun, 01 October 2017, 08:37:55 »
I have a separate Hakko fx888d soldering station.  You could use the desoldering gun to solder in a pinch, but you would need a different tip and it’s not really weighted right for precision.  It’s heavier in the back because of the pump and is a bit unruly for one handed use, at least for me.
