Author Topic: Best 144Hz G-SYNC 24-27" monitor?  (Read 3410 times)
Offline AuthenticDanger
« on: Thu, 21 September 2017, 16:27:29 »
I'm not sure I need 4K (but if I do, let me know ;)), so 1440p seems reasonable. The cheapest I saw was a 24" for $350, but is there a reason to spend more?
This monitor will be mainly used for for FPS gaming and video editing. Video card is a 1050 ti (though if I need to, I'll splurge on a 1080).
I'm guessing TP4 has an opinion on this.
Let me know what you recommend!
F Keys belong on the left.
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: Best 144Hz G-SYNC 24-27" monitor?
« Reply #1 on: Thu, 21 September 2017, 16:52:24 »
I'm interested in hearing opinions too. I have a 1070!
https://pcpartpicker.com/list/BCCL3F
Sent from my SM-G935T using Tapatalk
Offline hkf
  • your #1 fan
« Reply #2 on: Thu, 21 September 2017, 17:07:25 »
TN or IPS?
I use S2714DG (TN) from dell and its pretty good. Colour repro is not 100% (I have a 100% sRGB gamut calibrated benq a few meters away to compare) but for FPS its very nice.
« Reply #3 on: Thu, 21 September 2017, 17:12:00 »
TN or IPS?
I think TN because I don't case as much about color or viewing angle. Refresh rate is key here.
Offline hkf
  • your #1 fan
« Reply #4 on: Thu, 21 September 2017, 17:14:40 »
TN or IPS?
You should be able to pick it up for around 500 on a refurb sale w dell.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #5 on: Thu, 21 September 2017, 17:16:04 »
TN or IPS?
What's the BENQ you're using? Does that one fare well for gaming?
« Reply #6 on: Thu, 21 September 2017, 17:40:43 »
get the LARGEST,  ULMB monitor you can afford.
120 vs 144 doesn't matter,  but it has to support ULMB at that refresh rate..
ULMB is a night and day competitive advantage for FPS games.
« Reply #7 on: Thu, 21 September 2017, 17:51:34 »
Don't all G-SYNC monitors support ULMB?
« Reply #8 on: Thu, 21 September 2017, 17:53:30 »
No, not all..
but overall, you still have to look at the ULMB performance _Reviews_ of that monitor ,  because some have problems, it's a tricky feature to get perfect, yet most valuable for gaming.
Offline hkf
  • your #1 fan
« Reply #9 on: Thu, 21 September 2017, 20:27:49 »
TN or IPS?
BL2710PT, its AHVA panel (IPS derivative) but I use it for photo work.
