Author Topic: Bad number sense  (Read 2809 times)
Bad number sense
« on: Fri, 22 September 2017, 17:14:10 »
So I bought this dash cam..
All the reviewers were like,  you get ~7 hours using a 64gb microsd card.
I get the camera, tested it,  based on my calculation,  I would only get 6 hours and 19.32 minutes
//disappointment
Re: Bad number sense
« Reply #1 on: Fri, 22 September 2017, 19:01:22 »
Total ripoff.
My Chinese vacuum sealer from amazon isn't working so great either.
« Last Edit: Fri, 22 September 2017, 19:03:26 by SpAmRaY »
« Reply #2 on: Fri, 22 September 2017, 19:06:06 »
Total ripoff.
what's a vacuum sealer , like an oring ?
« Reply #3 on: Fri, 22 September 2017, 19:17:57 »
Total ripoff.
« Reply #4 on: Fri, 22 September 2017, 20:05:10 »
I guess the only choice is name-brand.. hahahaha
« Reply #5 on: Fri, 22 September 2017, 20:19:08 »
I once bought a SSD that advertised 350GB and it only had 324GB. THIEVES!
Offline pingmaster
« Reply #6 on: Sat, 23 September 2017, 07:42:51 »
Yea it did, just not partitionable space.
« Reply #7 on: Sat, 23 September 2017, 08:38:48 »
that depends, some have more than others..
