Author Topic: ha don't work on your pc while drinking guyz  (Read 2877 times)
Offline atarione
« on: Fri, 20 October 2017, 15:14:02 »
 :rolleyes:
was surprised by temps I saw on my pc today running prime95... opened case up..apparently a few months ago when I had this open I was distracted / possibly been drinking a bit..
blah blah opened pc case found this:::  BAHAHAHAHAA..... OOOPS
Offline mrhead
  • Thread \ (•◡•) / Stopper
Re: ha don't work on your pc while drinking guyz
« Reply #1 on: Fri, 20 October 2017, 18:21:32 »
So are all three (including the exhaust fan on the case) blowing in the same direction at least?
Offline atarione
« Reply #2 on: Fri, 20 October 2017, 19:17:17 »
they are now  :)
honestly I am not sure what was going on before.. I think the **misplaced fan was blowing the wrong way and fighting the other two..
airflow is all front to back now.. as it should have been before.. I just had one to many beers and forgot what i was doing...
Offline iLLucionist
  • Topre is Love.
« Reply #3 on: Sat, 21 October 2017, 16:50:28 »
Ahh yess the good ol' days of building PCs whilst drunk. I once literally forgot to put on the fans of the heatsink anyway. That was interesting... Turned out overheat protection does not always work.
« Reply #4 on: Sat, 21 October 2017, 17:26:16 »
more than once I've forgotten to plug the fan back into the power grid after reattachment.
I wasn't drunk though, I'm was just careless.
Offline iLLucionist
  • Topre is Love.
« Reply #5 on: Sat, 21 October 2017, 17:30:12 »
I once forgot to attach PSU cables. Instead of checking the cables, I thought the fan in the PSU was dead and that the mobo was dead or fried. I felt so stupid just noticing after 2 hours or something that I just forgot to plug in the main motherboard power connector.
Offline fanpeople
« Reply #6 on: Sat, 21 October 2017, 21:13:23 »
I almost called technical support for a laptop that was not turning on about 10 years ago. I opened the manual just to check the trouble shooting guide as  I figured they would ask me to go through that first anyway. The very first item on the checklist was to make sure the power point is switched on. I thought to myself what sort of ****wit would not know/forget to turn the power point on. Well turns out I was that sort of ****wit.
tl;dr Everyone does special things from time to time.
« Reply #7 on: Mon, 23 October 2017, 20:52:16 »
That's not as bad as having it plugged into a power board, and then having the power board plugged into itself.
Offline fanpeople
« Reply #8 on: Mon, 23 October 2017, 21:02:19 »
HAhaha yeah...... that is true
