Author Topic: Calling all da Azhun Peepoe, need a new rice cooker  (Read 5020 times)
Offline digi
  • elite af tbh
  • keyboard game on fleek
« on: Wed, 08 November 2017, 11:35:21 »
Time for a rice cooker upgrade. Is there a rice cooker that leaves the rice nice and dry and yummy? ^-^
Please only link cookers on Amazon, I don't buy from anywhere else. :D
Re: Calling all da Azhun Peepoe, need a new rice cooker
« Reply #1 on: Wed, 08 November 2017, 11:49:48 »
$600..
You're good to go. !!
$1200..
Godly Plate of the Rice. !!
Offline digi
  • elite af tbh
« Reply #2 on: Wed, 08 November 2017, 11:50:32 »
Link??
Offline digi
  • elite af tbh
« Reply #4 on: Wed, 08 November 2017, 11:55:09 »
I feel like this is the one..
https://www.amazon.com/Aroma-Housewares-ARC-914SBD-Cool-Touch-Stainless/dp/B007WQ9YNO/ref=sr_1_3?s=kitchen&ie=UTF8&qid=1510163621&sr=1-3&keywords=rice+cooker
It has two different buttons, one for Brown Rice and one for White Rice.....it's racist.
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #5 on: Wed, 08 November 2017, 11:59:33 »
« Reply #6 on: Wed, 08 November 2017, 11:59:49 »
I'd recommend at least 1050 ti lvl budget..
Fuzzy logic is important, because it cooks the rice more evenly.
For the 1030 lvl budgets,  they're mainly on/off circuits, and while that will cook your rice,  it does nothing for texture, and the top and bottom of the rice container will have larger mismatch.
« Reply #7 on: Wed, 08 November 2017, 12:01:50 »
However,  @ the 1070 lvl ..
You can get something made in japan..
It's not as good as the 1080ti where it's the Made in Japan SOLD IN JAPAN level rice cookers,   but it's pretty damn good.
@ the Titan XP lvl,    there are no wiggle rooms, It will be the best rice a machine can make @ home.
Offline digi
  • elite af tbh
« Reply #8 on: Wed, 08 November 2017, 12:01:52 »
Racist, do not buy.
That's exactly why I want it though..
Knew it..
Offline digi
  • elite af tbh
« Reply #9 on: Wed, 08 November 2017, 12:09:22 »
So Tiger is made in Japan. All my Azhun friend always haf da flower on da cooker, I think this is the one...There is always something different about their rice and mine...I think I found it.
https://www.amazon.com/Tiger-JAZ-A10U-FH-5-5-Cup-Uncooked-Cooker/dp/B000AOJ9W6/ref=sr_1_6?s=home-garden&ie=UTF8&qid=1510164474&sr=1-6&keywords=rice+cooker+tiger
« Reply #12 on: Wed, 08 November 2017, 12:18:21 »
It really comes down to how much rice you eat..
Tp4 eats 1500 Calories of Rice each day.. so that's 0.411 kg  or 0.9 lbs of rice..
Over a year, that's $330 of Raw rice..
The rice cooker should last at least 5 years..
$330*5 + $269 = $1919   for 5 Years of Rice-perience.
Offline digi
  • elite af tbh
« Reply #13 on: Wed, 08 November 2017, 12:20:31 »
Hmm, I can't argue with your brilliant math.
I'm closer to $79.23*3.14 / 65* 212.43 = $69
« Reply #14 on: Wed, 08 November 2017, 12:29:56 »
If we must be on budget..
look for Necessary Important Features.
Induction cooking
---  More even heating,  Larger heating surface area which include parts of the inner bowl walls
-----  vs standard cookers, which only has a heated bottom, and radiates heat upwards
Fuzzy Logic
---- Depending on Air pressure, proximal temperature, rice hydration lvl, water fill lvl,   Different heating program is necessary..
Brand
----  Fuzzy logic is a proprietary set of algorithms which comes from extensive testing
---  In that way, relative to the consumer,  a long standing company making such cookers w/ a degree of (rice pedigree)  has the best algorithms..
Offline dante
« Reply #15 on: Wed, 08 November 2017, 12:30:02 »
Old thread where I looked for suggestions on rice: https://geekhack.org/index.php?topic=66361.0
Offline digi
  • elite af tbh
« Reply #16 on: Wed, 08 November 2017, 13:02:07 »
Thanks for all the help guys
Offline digi
  • elite af tbh
« Last Edit: Wed, 08 November 2017, 13:11:49 by digi »
« Reply #19 on: Wed, 08 November 2017, 13:14:12 »
how much rice do you plan to eat..
One or twice a week
You probably don't need a rice cooker.. hahahaha
Short grain rice: 1.095 grams of water / gram of rice
Long grain rice: 1.3 grams of water / gram of rice
Basmati: 1.3-1.5 grams of water / gram of rice
Use pot with tight -non-vented- lid.
Bring to boil,   Reduce heat to ~15% above lowest setting, simmer for 4 minutes.
Do not open pot,  turn off heat, Cover lid with thick fuzzy towel, let stand for minimum 20 minutes..
Offline digi
  • elite af tbh
« Reply #20 on: Wed, 08 November 2017, 13:15:01 »
One or twice a week
Do not open pot,  turn off heat, let stand for minimum 20 minutes..
Das too muc work boi
