Author Topic: Topre From Most Tactile To Least Tactile  (Read 11221 times)
Offline Hyde
  • White Tofu Extraordinaire
« on: Thu, 16 November 2017, 22:42:34 »
Hello, as we all know Topre has 3 weights, 30g, 45g, 55g, but somehow ALL of them feel differently on different keyboard.
So I figure this might be helpful if we can compile a list for those that are in the market.  I personally don't own all the Topre boards for the ones that are missing I'll need your help to update the list.
I'll try to update as frequent as I can, also correct me if any info is wrong, here it goes:
MOST TACTILE
BKE Heavy Dome
BKE Light Dome (still need confirmation)
Realforce 55g
FC660C = FC980C (maybe?)
Type Heaven
Novatouch
HHKB
Realforce Hi-Pro
Realforce 45g
Realforce 45g Silent
Realforce Variable
Realforce Variable Silent
Realforce 30g
Realforce 30g Silent
LEAST TACTILE
To update reply which what keyboard also where it would be on the tactility list (tell me between which 2 keyboards).
« Last Edit: Sun, 03 December 2017, 14:27:41 by Hyde »
Re: Topre From Most Tactile To Least Tactile
« Reply #1 on: Thu, 16 November 2017, 22:51:41 »
you forgot RF 55g, should be high up on the list
also the BKE heavy domes are pretty tactile
Offline Dreamre
    • kbdlife
« Reply #2 on: Fri, 17 November 2017, 15:09:03 »
Where does the HHKB stack in this list?
Offline _rubik
« Reply #3 on: Fri, 17 November 2017, 15:37:09 »
BKE redux heavy domes are, from what I've heard and what I'll soon feel, the most tactile on that list.
Offline rich1051414
« Reply #4 on: Fri, 17 November 2017, 21:21:01 »
With tactility via rubber dome, logic dictates that the heavier weight the dome is, the more tactility.
Offline Hyde
« Reply #5 on: Fri, 17 November 2017, 21:39:26 »
Yeah I kind of wonder about this too, I'd imagine it's around FC660C's tactility.
But someone who have tried both please chime in.
I get the same impression too, maybe I'll put that in in the meantime until someone confirms otherwise.
We still need people who has experience with HHKB, NovaTouch and FC980C to comment on how tactile they are on this scale.
« Last Edit: Fri, 17 November 2017, 21:43:58 by Hyde »
Offline kmba
  • Formerly tameone
« Reply #6 on: Fri, 17 November 2017, 23:24:31 »
Hhkb is right around rf 45g.. noticably less tactile than fc660c since the Leopold is in fact heavier than 45g. All I have to compare is a variable rf but the middle keys should be 45g so I'll do a 1-1 later
keyboards.
Offline Hyde
« Reply #7 on: Sun, 19 November 2017, 17:40:28 »
Ohhhh, that might explain why when trying FC660C and Type Heaven I feel "just right" and Realforce always feels lightly too light for me.
Would you say HHKB is probably in between Leopold and Realforce?
« Reply #8 on: Sun, 19 November 2017, 17:43:52 »
They all have to be worn exactly evenly..
And the test environment has to be temperature controlled.
And as you type, you have to type identical text, at approximately the equivalent pace.
Offline mpalen19
« Reply #9 on: Mon, 20 November 2017, 19:18:32 »
Hello, I own a Novatouch, Leopold FC660C & a Realforce 87U (55g). While stock, the Novatouch felt slightly lighter compared to the Leopold but not by much. However, after modifying both the Novatouch and the Leopold with Hyperspheres rings, they now both feel very different to me. The Leopold feels a bit more tactile whereas the Novatouch lost all of it's tactility after the installation of the Hyperspheres. The Realforce on the other hand remains stock and therefore retains higher tactility compared to both the Leopold & the Novatouch. I originally bought the Realforce with the intent of switching the domes over to the Novatouch given their lack of tactility after the Hypersphere install. Now that BKE Redux 60 gram domes are available I might forgo the swap and use the 55 gram domes for the Leopold instead. Sorry if my post went on a slight tangent. Thought I'd give my impression with the stock versus modified of the 3 Topre boards that I own.
Leopold FC660C / Norbatouch / Realforce 87U /  KUL ES-87 / Rama M60-A / Fjell
Offline Hyde
« Reply #10 on: Mon, 20 November 2017, 23:03:54 »
LOL it's ok I'm glad I'm not the only one. Everyone praise the 3rd party silence rings so much but I always wonder if I am the only one to think there is too much lost in tactility.  I like the solid feel of silencing but now I'm not sure if the lost in tactility is worth it.
And don't worry now I finalky have data on Novatouch I'll put in a rough list for now and if anyone have more data later I can always correct the list.
Offline Hyde
« Reply #11 on: Fri, 24 November 2017, 10:47:11 »
I read conflicting reports on HHKB tactility being heavier / lighter than Leopold.
One source find HHKB closer to 45g Realforce the other source find it inbetween 45g and 55g Realforce (Though I guess Leopold kind of fall under this too).
Can anyone who own both confirm this?
Offline macguy80
« Reply #12 on: Sat, 25 November 2017, 01:40:18 »
Can anyone comment on where the Topre Hi-Pro (104UG) would fit in the ranking?
Offline daskeybo
« Reply #13 on: Sat, 25 November 2017, 09:21:04 »
Exactly.  This is too subjective.
Somebody claimed there is a 25g Topre:
https://geekhack.org/index.php?topic=92512.msg2524093#msg2524093
« Last Edit: Sat, 25 November 2017, 09:22:38 by daskeybo »
Offline Hyde
« Reply #14 on: Sun, 26 November 2017, 11:30:14 »
I tried it a long time ago I think it was quite tactile compare to Realforce for sure, though weight probably lighter than Leopold maybe I'll shove it somewhere in the middle for now.
Yeah I'm not trying to be that precise, it's more meant as a buying guide for people who wants to try their first Topre.
:P
If anyone has first hand on any of this feel free to correct me, this is currently based on estimation from people's feedback + I own some of the keyboards.
« Last Edit: Sun, 26 November 2017, 11:40:29 by Hyde »
Offline phinix
« Reply #15 on: Mon, 27 November 2017, 03:56:19 »
Are these BKE Redux 60 gram domes similar or very close to original Topre ones?
I remember those cheap chinese versions from ebay - I hope these are closer to original in terms of quality etc?
Offline czarek
  • Keep the momentum going!
    • FalbaTech
« Reply #16 on: Mon, 27 November 2017, 08:52:10 »
All fine, but Topre tactility is just like RGB LEDs - a decoration as it doesn't tell you when the switch activates. Feels good though.
Offline SamirD
« Reply #17 on: Fri, 01 December 2017, 00:34:50 »
This is VERY helpful for those of us looking at Topre and wondering what to get.  A big thank you!  :thumb:
Offline loud_asian
« Reply #18 on: Fri, 01 December 2017, 13:15:10 »
BKE lights in an HHKB are more tactile than 55g in a Realforce in my opinion
Offline teraflame
« Reply #19 on: Fri, 01 December 2017, 13:23:02 »
Hyperspheres definitely suck, the kbdfans silence-x were great as they're much thinner. I don't feel a negative difference with them.
Rubber in domes
Offline Hyde
« Reply #20 on: Sat, 02 December 2017, 17:35:17 »
lol no problem, I still need more feedback so the list might not be 100% correct but for now you guys can use it as a rough guideline.  :)
lol ok I'll add it to the list.  Thanks!
I do really want to try this one day though.
After using both for a while I find they both have their pros and cons.  I wouldn't say they suck but they both have their pros and cons.
I find hypersphere dampen the best so it feels super solid and no wobble at all, drawback is that it kills tactility and has travel reduction.
KBDFans rings sort of dampen decently and doesn't reduce travel much, but it's one of those jack of all trades mater of none situation.  I find it not bad but it didn't dampen as much as I hoped for, so next up I want to try stock silent.  :thumb:
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #21 on: Sun, 03 December 2017, 01:18:57 »
My 660c was less tactile than my RF45g but maybe that was 'aged' domes? I dunno. The rest i agree with.
-Dana
Offline Hyde
« Reply #22 on: Sun, 03 December 2017, 14:24:23 »
LOL funny enough I notice the same thing.
My wife's FC660C started out more tactile than my Realforce 45g, but now it's less tactile but my assumption is also probably because she use it heavily at work so maybe more wear and tear.
I also notice some of the domes are more worn out than others, so I do strongly suspect it's wear and tear.
Topre just doesn't have the same durability as Cherry MX I guess.  :(
Offline OfTheWild
« Reply #23 on: Sun, 03 December 2017, 14:26:37 »
My understanding is that the rubber domes actually get stiffer as they age - or maybe only if they're unused for a long time? anyway, they all started out as 45g I just feel like the plastic hhkb gets a little more 'thock'
-Dana
Offline rich1051414
« Reply #24 on: Mon, 04 December 2017, 04:55:41 »
It depends on the 'rubber' used and how much the keyboard sat vs has been used. Some rubbers will dry up over time, which will make them stiffer, but heavy use will crease the rubber, causing a reduction in weight and tactility.
Offline Hyde
« Reply #25 on: Mon, 04 December 2017, 13:12:22 »
Yeah I get the same impression too, maybe I should let this keyboard sit for a while to regain tactility.  :P
Offline OfTheWild
« Reply #26 on: Mon, 04 December 2017, 19:59:12 »
I think that would equate to years though.
-Dana
Offline HotRoderX
« Reply #27 on: Mon, 18 December 2017, 15:34:33 »
Honestly I would say the 55g Realforces are not as tactile as the FC660c. I just got the 87UB55
