Author Topic: Reformed PC Display Recommendation.  (Read 2312 times)
Online tp4tissue
« on: Fri, 17 November 2017, 01:51:40 »
VA panel.
--much better than ips for contrast and blacks, (an HDR color space consideration)--
At least 120hz
--minimum requirement for 24p judder free ulmb--
ULMB
--Motion clarity requirement--
3840x2160
--1:1 pixel UHD Movies compatibility--
Minimum, 50 inches diagonal..
--Viewing distance 1.5 meters for text to 2.5 meters for movies and games--
Re: Reformed PC Display Recommendation.
« Reply #1 on: Fri, 17 November 2017, 08:13:30 »
sqrt(3840**2 + 2160**2) / 50.0 or more  = 88.12 PPI or less. Are you serious?
Online tp4tissue
« Reply #2 on: Fri, 17 November 2017, 08:44:46 »
Correct.
Viewed @ 1.5 to 2 meters away.  It's about as big as a 27-30 inch viewed from 2-3 feet
It's critical that screens are viewed at greater than 1.5 meters distance to maximize eye comfort.
