Author Topic: TEX YODA II - DIY kit (Special Edition)  (Read 12538 times)
Offline sdiearly
« on: Wed, 22 November 2017, 03:22:55 »
Hi guys,
I had received and assembled my YODA II last week.
Here are some pictures to show my kit and how to assemble TEX YODA II.
https://imgur.com/gallery/OK9fy
The package of DIY kits from TEX design. Icons list what is contained in this box.
TEX logo is printed in the corner.
After opening the box, the top layer shows we have the keycaps that TEX provided for possible layout on YODAII
(Actually there is a lack of Cherry's stepped Capslock key )
These keycaps are made in Taiwan.
Below the keycaps, we can see there are pictures show procedure of DIY, and slogan "Think different, Make different"
What's inside? these parts also are with pictures for cross check.
Yoda II PCB / 3 mouse key PCB / CNC case / Plate
This color is designed by Justin@TEX.design, he provides four pieces for friends.
The inner side of CNC case.
Back side of CNC case, Five screw holes for KB PCB/ two holes for 3 mouse key PCB.
What's a joke!!! extra two feet Justin sent to me.
USB cable / LEDs / Stabilizer(GMK)
Trackpoint module and three different type of hats.
Follow the DIY procedure. step1 : Install Cherry switches on the plate
Step2 : Install GMK stabilizers on PCB and combine with plate together.
Step3 : Soldering
Bypass step4 and go to step5: LED and switches function test
Step4 : Install Trackpoint module
Step6-1 : Connect three mouse PCB then go to assembly. TEX's procedure missed this item.
Step6 : Assembly
Waiting for keycaps now , I have sent four sets of GHB keys to Justin and ask him for hole drill processing.
The left one is YODA I, which is also friend edition
Five TEX products are lay on my wall.
If I install keycaps with TEX's default ones. I have to replace another one for capslock.
My favorite 60%:  TEX-Beetle
                 80%:  KBtalKing Race
                100%: Cherry G80-3494, Zowie Celeritas
Offline MNZT
  • Software Engineeeeeerd
Re: TEX YODA II - DIY kit (Special Edition)
« Reply #1 on: Wed, 22 November 2017, 05:02:47 »
Nice post, and collection!
How does the pointer 'nipple' feel? I rarely use the one on my Lenovo laptops, interesting to see how the trackpoint compares when on a mech board.
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #2 on: Wed, 22 November 2017, 07:16:37 »
Hmm.
One needs to drill holes in the G, H and B keys to fit the trackpoint module?
How well would this work as a travel keyboard with the ALU case?
Offline hanya
« Reply #3 on: Wed, 22 November 2017, 07:59:39 »
Thanks for sharing these images.
So, the trackpoint module is the same one which has been choosen by UHK. Arrangement of the component on the module are the same with the datasheet which can be seen in:
https://github.com/UltimateHackingKeyboard/datasheets/blob/master/trackpoint/trackpoint_module.pdf
PFU HHKB JP, Sanwa MA-TB38 trackball
« Reply #4 on: Wed, 22 November 2017, 08:25:16 »
why didn't they just move the keys over one slot so people won't have to drill their precious keycaps.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #5 on: Wed, 22 November 2017, 21:15:43 »
I always wonder if you can just ignore the trackpoint module (it's a bit of a waste I know).
BUT then you map the mouse buttons to FN button so that way you have easy access FN key without changing your typing posture also without needing custom sized spacebar (i.e. Filco Minila).
I'd test this myself but too bad I can't use 60% keyboards (need arrow key + number pad, a lot).
Offline Gajible
« Reply #6 on: Wed, 22 November 2017, 21:31:00 »
Hot damn, how'd you get that colour?
Offline jakllsch
« Reply #7 on: Tue, 20 February 2018, 08:17:47 »
How is the height of the trackpoint cap with Cherry-profile keycaps?  It seems the OEM-profile keycaps give a realatively flush trackpoint, similar to ThinkPads; I'm worried that it'd protrude a bit too much on lower-profile keycaps.
Offline jakllsch
« Reply #8 on: Thu, 22 February 2018, 05:59:19 »
To answer my own question: https://www.flickr.com/photos/jewu8210/sets/72157661967953577 has photos of a Yoda II w/ GMK keycaps.
Offline TheInverseKey
  • You can run but you cannot hide!
« Reply #9 on: Thu, 22 February 2018, 09:50:48 »
How does the trackpoint compare to lenovo laptops in the rate of speed and precision?
Also is there any cursor drag: when the cursor starts dragging by itself across the screen to a certain location.
Thanks
