Author Topic: Microscopez  (Read 2866 times)
Microscopez
« on: Fri, 24 November 2017, 09:12:08 »
Ya'll got one of these ?
Looking for light optical..
what's the highest magnification i can get for $500..
not looking at slides, looking at metal surfaces.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Microscopez
« Reply #1 on: Fri, 24 November 2017, 09:19:51 »
Bleh, light microscopes are ****e. Electron microscopes are where it's at!
Have you got a spare 2 million or so?
Re: Microscopez
« Reply #2 on: Fri, 24 November 2017, 09:23:38 »
I'm not @ that lvl.. hahahaha
it's between microscope or a 1080ti..
i guess i could swing a $700 microscope, But i wanted to get a $500 microscope, and then do up a servo kit for it with the remaining $200..
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Microscopez
« Reply #3 on: Fri, 24 November 2017, 11:30:06 »
Huh, I literally added a cheapo usb vidya microscope (with lcd) to my tool list yesterday. gee-whiz
Re: Microscopez
« Reply #4 on: Fri, 24 November 2017, 12:28:47 »
i was thinking telescope as well,  but then i thought.. Outside + Tp4 = Death of Tp4..
Offline TalkingTree
    • My projects
Re: Microscopez
« Reply #5 on: Fri, 24 November 2017, 12:42:36 »
I'm not a metallography expert but I don't think you need a cytology microscope for that, let alone a TEM.
Optics' prices vary dramatically depending on the manufacturer but if you're doing it for the sake of curiosity, a professional $300 optical microscope will do just fine, at least for starters.
I have a Hund Wetzlar V200 at work with 4X, 10X and 40X lenses which you could find, used, for about $200 and does the job.
Re: Microscopez
« Reply #6 on: Mon, 27 November 2017, 19:55:23 »
I have a normal sized scope.
I believe there are procedures now to help those with microscopes.
  • Live long and prosper
Re: Microscopez
« Reply #7 on: Mon, 27 November 2017, 20:33:50 »
i read the title as 'micropez' and was like dafuq aren't Pez already small enough???
tp thread is tp thread
Re: Microscopez
« Reply #8 on: Mon, 27 November 2017, 21:06:44 »
Need m0ar pezz.
Re: Microscopez
« Reply #9 on: Tue, 28 November 2017, 20:01:52 »
Not small enough if you need a microscope to see them.
