Author Topic: Ejecting switches from plate  (Read 3122 times)
Offline math225r
« on: Tue, 23 January 2018, 07:11:50 »
I just got my things for my first keyboard and without thinking i started popping the switches into the plate. Then later i realized that i won't be able to place it into the pcb properly (I have a hotswap pcb). Does anyone know how i most effectively remove the switches again?
Offline xondat
  • i'm not a star
Re: Ejecting switches from plate
« Reply #1 on: Tue, 23 January 2018, 07:13:47 »
Push those pins in and lift out.
Offline math225r
« Reply #2 on: Tue, 23 January 2018, 07:17:13 »
But how tho, the keycaps are so close together so I obviously can't use my fingers...
Offline itskuroi
« Reply #3 on: Tue, 23 January 2018, 08:11:39 »
I use a small flathead to do it one at a time.
Offline Harms
« Reply #4 on: Tue, 23 January 2018, 12:04:43 »
Try using an IC extractor tool :).
« Reply #5 on: Tue, 23 January 2018, 12:30:57 »
i've done both of these things and they both work fine
« Reply #6 on: Tue, 23 January 2018, 12:36:16 »
As you can see the bottom of the switch you can press the sides in below the tabs, bigger target and any scratches will be on the underside of the plate so not visible once the board is built.
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #7 on: Mon, 29 January 2018, 22:45:13 »
I screwed around for a few years before finally buying this... so much easier: https://1upkeyboards.com/cherry-switch-puller.html
-Dana
« Reply #8 on: Mon, 29 January 2018, 22:50:04 »
this is an IC chip remover, as mentioned above
Offline OfTheWild
« Reply #9 on: Tue, 30 January 2018, 01:03:13 »
Ah ok, that makes sense then!
Well definitely get one of these!
-Dana
« Reply #10 on: Tue, 30 January 2018, 09:15:20 »
you only need to push one side,  then press the little protruding nub from below the pcb
Offline rich1051414
« Reply #11 on: Tue, 30 January 2018, 11:38:44 »
If you have problems with ic pullers bending on you, you can use the kind that are bi-directional, they lift towards you as you put extra pressure on them, they are very quick.
They look like this:
187548-0
I want to point out that these can damage things if not used correctly tho. If you are misaligned so you aren't depressing the clips, it will rip right through the plastic from the mechanical advantage. They also don't spring open on their own, so it can be awkward in tight spaces.
Personally I would like a traditional IC puller that doesn't bend outwards on you on tough to pull switches, but I haven't found one yet.
« Last Edit: Tue, 30 January 2018, 11:46:50 by rich1051414 »
