Author Topic: Anyone knows the size and/or spec of the black screws in the Realforce?  (Read 2679 times)
Offline nguyenhimself
I disassembled my Realforce 87U to switch in the BKE Redux domes. But then I had to leave in  a hurry, so I packed up all the screws inside a small packet... only to lose that packet the next day.
And so, can anyone tell me the name/spec/size of these black screws so that I can maybe go buy some replacements? Thanks a lot!
« Last Edit: Fri, 26 January 2018, 19:55:02 by nguyenhimself »
Offline Hyde
  • White Tofu Extraordinaire
Re: Anyone knows the size and/or spec of the black screws in the Realforce?
« Reply #2 on: Sun, 28 January 2018, 01:35:35 »
Unfortunately I can't find a ruler at home so I will have to resort to a very geekhacker solution, using your keycap legends to measure!
Black screw is starting from t all the way to edge of arrow stem.
187409-0
Width is same as arrow stem.
187411-1
White screw is from t to middle of s.
187413-2
Now you just have to measure your Realforce shift key LOL.
Offline Deefenestrate
« Reply #3 on: Sun, 28 January 2018, 09:29:22 »
Nice pic!
Offline 1391406
« Reply #4 on: Tue, 30 January 2018, 17:46:55 »
Get a ruler app for your phone and measure it on the screen.
« Reply #5 on: Tue, 30 January 2018, 17:51:40 »
I've tried this,  they're usually off by 0.2mm-0.5mm depending on resolution
« Reply #6 on: Tue, 30 January 2018, 19:02:12 »
Thanks a lot you guys. I'm currently traveling for work, but I will try this again as soon as I get back home.
