Author Topic: jesus, has anyone ever gotten this to work ?  (Read 3206 times)
« on: Sat, 24 February 2018, 10:31:19 »
Saw this on lifehack years ago
Have tried it a billion times,  the smaller piece never sticks, and eventually just falls off..
Re: jesus, has anyone ever gotten this to work ?
« Reply #1 on: Sat, 24 February 2018, 11:30:40 »
Are you kidding? I always do this, and have for decades.
Both bars need to be wet and somewhat softened when you stick them together, and need to dry and harden a minimum of 12 hours.
- D Trump 2026-10-24
« Reply #2 on: Sat, 24 February 2018, 14:21:12 »
Fohat make soap stick tutorial .. !!
« Reply #3 on: Sat, 24 February 2018, 15:26:32 »
uhh dude, literally all you need to do is rub the edges under warm water till they weld together. my 5 year old cousin could figure this out tp, are you drunk?
« Reply #4 on: Sat, 24 February 2018, 15:33:36 »
Dis is nuts..  how come everyone else got this to work..
This is what happens,  I take the two pieces (when wet), put them together.  give it a good squeeze..
Then I leave it,  the next day, when I try to use it, it will stay together to some extent,  but inevitably, it comes back apart..
Offline p_blaze
« Reply #5 on: Sat, 24 February 2018, 15:41:09 »
Depends on the soap. Certain soaps is ez, but I think stuff like Dove don't work
« Reply #6 on: Sat, 24 February 2018, 16:00:53 »
I've had no success with lever 2000, irish spring, or dove..
Those are the only ones i've bought ever, because they're the cheepest.
« Reply #7 on: Sat, 24 February 2018, 16:41:57 »
Dove works fine but non-flat surfaces are harder to meld together unless 1 of the pieces is thin enough and soft enough to spoon itself onto the other one.
Also oilier soaps work better than drier soaps like Dove.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #8 on: Sat, 24 February 2018, 17:40:11 »
I didn't even know this was a hack, been doing it for years. Definitely works.
« Reply #9 on: Mon, 26 February 2018, 19:55:48 »
Same here.
Sometimes doesn't work, but then the shower drips occasionally which prevents the join from bonding properly.
