Author Topic: Metal Keyboards?  (Read 5914 times)
Offline cdutoit
Metal Keyboards?
« on: Fri, 02 March 2018, 14:11:45 »
Ok, maybe not 'metal' but...
I've recently acquired a number of MK's, partly to find one I like as well as to do reviews of the keyboards. The one I'm enjoying most is actually my DAS professional 4 with Cherry Blues. Now, switch aside, I really like the actual keyboard because of it's heft. Nothing rattles...no pings...no moving around on my desk. And it doesn't look like a piece of plastic. All thanks to that aluminum plate on top of the keyboard.
Now, I need to get a quieter keyboard for the office. I'd like to get one with Cherry Red Silents. Ideally, I'd have bought another DAS but they don't make them with those switches.
So my question is which of the "off-the-shelf" keyboards have a good, almost steel/metal, feeling? I don't want something "plasticy"...either in appearance or feel if that makes sense. If nothing "off the shelf" meets those criteria, which custom kits should I perhaps look at?
If I get some recommendations I can go look to see if they come with silent reds.
Thanks for any suggestions
Offline dubious
  • 쏘쿨
Re: Metal Keyboards?
« Reply #1 on: Fri, 02 March 2018, 14:31:13 »
pokers come with a metal tray style case, if you like 60%'s
CODE/WASD are plastic keyboards, but they feel well made and solid. Same with filco/leopold
Some TEX keyboards are aluminum, and some have aluminum top housings
Magicforce has an alloy case, but feels pretty cheap IMO
etc..
Offline Techno Trousers
  • ʘ_ಠ
« Reply #2 on: Fri, 02 March 2018, 14:46:50 »
IKBC MF87 and MF108. I think you want to get the "version 2" one.
Offline JP
« Reply #3 on: Fri, 02 March 2018, 15:11:34 »
Metal keyboards you say  :cool:
190197-0
About Me | The Collection
« Reply #4 on: Fri, 02 March 2018, 15:59:08 »
If you like the DAS so much just swap silent reds into one.
Offline Entropia
« Reply #5 on: Sat, 03 March 2018, 10:05:33 »
This one is even more impressive:
« Reply #6 on: Sat, 03 March 2018, 11:01:43 »
no one has done full metal switches yet..
it would be tremendously wasteful and decadent..
« Reply #7 on: Sat, 03 March 2018, 11:45:45 »
this
Offline buckyballs
« Reply #8 on: Wed, 07 March 2018, 06:25:57 »
You're just talking about the casing, right? Aren't these still fairly common? I think it just makes a keyboard too heavy to move around.
Offline rich1051414
« Reply #9 on: Wed, 07 March 2018, 14:11:36 »
Nothing will feel quite as 'solid' as a good custom, but there's a lot of options without needing to do a complete custom job, like getting a filco(or CM quick fire rapid) and replacing the body with one of milled aluminum. You could use one of these as a murder weapon.
Theres a drop for such a case right now: https://www.massdrop.com/buy/lambo-80-anodized-aluminum-case-for-filco-87-tkl
I built a KBFans75 a while ago, and I was shocked at how solid a keyboard could be. I really notice it when a keyboard feels flimsy now.
« Last Edit: Wed, 07 March 2018, 14:18:21 by rich1051414 »
« Reply #10 on: Wed, 07 March 2018, 14:51:41 »
Offline buckyballs
« Reply #11 on: Thu, 08 March 2018, 02:51:01 »
Even at $165 is too much for me poor old pocket  :rolleyes:
Offline nogoodnames444
  • I like keyboards
« Reply #12 on: Thu, 08 March 2018, 20:44:03 »
LEOPOLD
Offline ppp
  • KappaKeepoKoopa
« Reply #13 on: Mon, 12 March 2018, 09:10:53 »
https://kbdfans.myshopify.com/products/gbkbdfans-8x-mechanical-keyboard-kit
this is good ****
I have a question about kbdfans stuff. It always seems like all their stuff is suggested after the post says the "group buy" is over. Is this extras or do they just keep producing them with the machinery they configured for it?
Offline rich1051414
« Reply #14 on: Mon, 12 March 2018, 20:14:09 »
this is good ****
The thing is, by the time people get their stuff and know whether to recommend it or not, the group buy is over. Group buys are to help fund the initial run of a product. The profits of that run are then used to fund additional runs at the full retail price. At least, this is the idea. Sometimes the group buy actually costs more than the eventual actual release, it depends on interest.
Offline ppp
  • KappaKeepoKoopa
« Reply #15 on: Mon, 12 March 2018, 21:01:38 »
Ah. So the listed price on kbd is the retail price. Got it. Thanks!
Offline rich1051414
« Reply #16 on: Mon, 12 March 2018, 23:35:36 »
Probably not, going off the price of other similar products. I think that was the group buy price. I assume that if/when this product is kept in stock, it will actually be $25-50 cheaper. Group buys aren't always cheaper, and many times the cost will decrease the more people who pledge to buy it. If there aren't a lot of pledges, then the group buy is likely to cost even more instead.
« Last Edit: Mon, 12 March 2018, 23:38:17 by rich1051414 »
Offline xueyao
« Reply #17 on: Mon, 12 March 2018, 23:48:47 »
The OG metal keyboard: Beamsprings
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #18 on: Tue, 13 March 2018, 07:35:39 »
Offline rich1051414
« Reply #19 on: Tue, 13 March 2018, 15:04:12 »
What's that? Looks like the numpad on ATM machines, but a whole keyboard...
Offline Kyi195
« Reply #20 on: Tue, 13 March 2018, 15:10:39 »
Some old kiosks will use that keyboard along with a trackball for mouse support.  There were some burried in closets where I work that we just had to surplus.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #21 on: Tue, 13 March 2018, 15:14:48 »
Usually public kiosks that may be subject to vandalism.
« Last Edit: Tue, 13 March 2018, 15:18:38 by Blaise170 »
