Author Topic: HHKB - is it possible to fix USB hub power problem?  (Read 2384 times)
Offline phinix
« on: Wed, 07 March 2018, 19:30:46 »
Is it possible to fix this low power problem for USB hub?
I know there is HASU controller, but you lose USB hub..
I would like to use this USB hub for pendrives, external HDD etc
Re: HHKB - is it possible to fix USB hub power problem?
« Reply #1 on: Wed, 07 March 2018, 19:42:19 »
you can probably find a usb hub controller chip that will fit inside the hhkb. Then jump all the wires.
Offline phinix
« Reply #2 on: Thu, 08 March 2018, 05:31:11 »
Alright, thanks. I thought there would be solution there already, I don't want to play soldering etc too risky:)
I don't understand whats the point of selling keyboard with usb hub where ts not working from the beginning...?
Offline Sup
« Reply #3 on: Thu, 08 March 2018, 14:55:15 »
Those USB hubs can't even power a USB 2.0 only thing it's useful is a wireless adapter for a mouse.
current
Coming soon
« Reply #4 on: Thu, 08 March 2018, 15:04:08 »
Maybe logi  G403
