Author Topic: Suggestion for ultrasonic cleaner that isn't too expensive?  (Read 10911 times)
Offline Blaise170
  • ALPS キーボード
    • XYZ
« on: Mon, 12 March 2018, 10:51:41 »
I sometimes end up with REALLY dirty keycaps that look like they've been buried in the mud for decades. I usually use soap and denture tablets to clean them, but then I still have to through every single keycap and wipe it down which gets very monotonous, very fast. I'm hoping there is a decent ultrasonic cleaner for under $50 or so that will do at least 80-90% of the work for me, if such a device exists.
Re: Suggestion for ultrasonic cleaner that isn't too expensive?
« Reply #1 on: Mon, 12 March 2018, 11:04:04 »
Does ultrasonic clean better than say,  a blender ?
Cuz you can get one of them cheapo blenders.. put a small piece of perforated aluminum above the blades, fill it with soapy water, then throw the caps in.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #2 on: Mon, 12 March 2018, 11:19:29 »
From my experience ultrasonic works very well. Using a blender sounds like a recipe for disaster.  :eek:
« Reply #3 on: Mon, 12 March 2018, 19:06:23 »
If you look at the dishwasher, it's really just a big blender..
Offline Tactile
« Reply #4 on: Mon, 12 March 2018, 21:58:05 »
I have one like this and it works great. It holds a full 104 cap set and makes them look like new in about twenty minutes.
REΛLFORCE
Offline Giorgio
« Reply #5 on: Mon, 12 March 2018, 22:37:25 »
This one is quite strong.  2l is the absolute minimum for keys. 3l can be useful for more objects.
https://m.ebay.com/itm/VEVOR-Commercial-Ultrasonic-Cleaner-3L-Heated-Ultrasonic-Cleaner-with-Digital/302629999952?hash=item4676275550:g:UJMAAOSwKgdaeflV
It gives really good results. The link is only to suggest the product, not the most cheap option. I've paid mine 90 EUR including delivery.
The best professional brand is Branson, widely used in chemical laboratories
« Last Edit: Tue, 13 March 2018, 04:13:37 by Giorgio »
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #6 on: Thu, 15 March 2018, 14:22:51 »
Bought a cheap Chinese one for $14. Hopefully it will work well enough to get a few keysets done and then once I actually have the money I can get a professional one.
Offline Kennedy
« Reply #7 on: Tue, 17 April 2018, 08:06:13 »
Hi,
Even though you have purchased one, I have another suggestion if somebody is looking for the same.
I found a video, thought of sharing it.
I checked the price, its $19.99. https://www.ebay.com/p/Baku-MCU-Intelligent-Drive-Ultrasonic-Cleaner-Bk-9050-110v-White/878714108?iid=122973117484&chn=ps
« Reply #8 on: Tue, 17 April 2018, 09:10:34 »
Hi,
That's kinda sketchy.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #9 on: Tue, 17 April 2018, 09:22:09 »
I have one of those. They aren't terrible, but I'm hoping to find a solution that works well since it seems like water alone doesn't work very well.
« Reply #10 on: Tue, 17 April 2018, 09:26:51 »
Did you try the denture tabs in the ultrasonic cleaner with the keycaps?
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #11 on: Tue, 17 April 2018, 09:41:42 »
Haven't tried that, no. Didn't think of that.
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #12 on: Tue, 17 April 2018, 10:39:41 »
I own this one: https://www.amazon.com/Elite-Ultrasonic-Jewelry-Cleaner-Professional/dp/B072MJGBJB/ref=sr_1_41?ie=UTF8&qid=1523979592&sr=8-41&keywords=ultrasonic+cleaner
I've cleaned caps, stabs, switch parts (stems and housings), and other crap around the house with it. It works nicely on plastics with warm water and dish soap mixed in a bit.
