Author Topic: Starting a chainsaw  (Read 2794 times)
Online tp4tissue
Starting a chainsaw
« on: Sun, 18 March 2018, 14:28:05 »
Pulled a Muscle.. !!
Why is Outside, so Difficult
Online tp4tissue
Re: Starting a chainsaw
« Reply #1 on: Sun, 18 March 2018, 15:01:28 »
Ok , so the between the leg start..
Does the handle go all the way up to the groin,  or is it pinched half way right before..
I can't tell from the videos.
Is there a difference between the slightly side ways between the leg start, and the all the way up the leg start ?
Offline clasicks
  • Formerly KeyboardUser4
« Reply #2 on: Sun, 18 March 2018, 15:05:32 »
place saw on ground, place foot in hand hold, pull cord.
Online tp4tissue
« Reply #3 on: Sun, 18 March 2018, 15:33:07 »
Yea I've successfully started the saw.. but I want to do it the Kewl manly way..
Offline clasicks
« Reply #4 on: Sun, 18 March 2018, 15:34:07 »
Manly way is ez once saw is warm and in use - just hold in one hand pull with other
« Reply #5 on: Sun, 18 March 2018, 15:53:57 »
TP4 what in the world could you possibly be doing with a chainsaw?
Online tp4tissue
« Reply #6 on: Sun, 18 March 2018, 16:09:44 »
Tp4 cut dat' w00d.. !!
« Reply #7 on: Sun, 18 March 2018, 17:25:07 »
You got to hold the blade between your legs when revving it
Online tp4tissue
« Reply #8 on: Sun, 18 March 2018, 19:23:02 »
it has grease on it..  oil all over pants ..
« Reply #9 on: Sun, 18 March 2018, 20:42:47 »
tp4 got to be vewwwwwy caweful when stawting a chainsaw held between the legs.
