Author Topic: HHKB Pro 2 case and topre Questions  (Read 3669 times)
Offline MC Qwerty
« on: Sat, 24 March 2018, 16:20:21 »
Hey everyone just domineering a few questions,
1. What material is the HHKB pro 2 made of? I am wondering if you can dye it
2. How easy it to give it a custom spray paint job and has anyone done it before
3. Any ideas on how to color the case
4. Topre switches - are they worth it,
5. Which are the best sliders which have MX mounts that are still in production and should I get silencing rings
6. Are they worth it?
Thanks guys :)
MC Qwerty
Offline MC Qwerty
Re: HHKB Pro 2 case and topre Questions
« Reply #1 on: Sat, 24 March 2018, 16:21:00 »
Ow also what mods should I put on an HHKB pro 2
MC Qwerty
« Reply #2 on: Sat, 24 March 2018, 20:42:27 »
The general advice on Topre is to Make sure you TRY one before you buy it.
The Hype is sky-high, so in order to be realistic about expectations.. that's the most practical approach.
Offline MC Qwerty
« Reply #3 on: Sun, 25 March 2018, 03:45:53 »
Thanks
MC Qwerty
Offline 00
« Reply #4 on: Sun, 25 March 2018, 03:52:05 »
Thanks guys :)
1. ABS.
4. That all depends on you.
6. I personally don't think so, they are notorious for being wobbly, scratchy and not fitting some caps properly.
It's like, dude, you gotta re-evaluate
Your perspective and your priorities, because
You started doing this because it was ****ing fun, you know?
It has to be fun
Otherwise, you're just torturing yourself, you know?
You're... you're just stuck inside your own ****ing head
Offline Belfong
« Reply #5 on: Sun, 25 March 2018, 03:53:40 »
HHKB is the best keyboard there is. The feeling is one of a kind.
Offline MC Qwerty
« Reply #6 on: Sun, 25 March 2018, 05:09:39 »
Thanks guys  what about the realforce 87u
MC Qwerty
Offline Belfong
« Reply #7 on: Sun, 25 March 2018, 21:47:51 »
I also own a Realforce 87UB, 55g weighted Topre switches. It's nice.. but I still like the feel and mystic thock sound of the HHKB.
« Reply #8 on: Mon, 26 March 2018, 16:59:38 »
Yeah I did sell the 55g Realforce from Massdrop after comparing it with the HHKB for a couple of months. That HHKB sound is addictive.
Offline MC Qwerty
« Reply #9 on: Tue, 27 March 2018, 06:24:44 »
Cool Thanks
MC Qwerty
Offline Sup
« Reply #10 on: Tue, 27 March 2018, 08:14:26 »
Painting is not that hard but time consuming. You have to use fine sand paper clean and then clean it from any skin oil or other substances. And then multiple layers of primer and then the paint to your liking.
current
Coming soon
Offline Wobbled
« Reply #11 on: Thu, 29 March 2018, 21:13:52 »
ABS, it can not be dyed very easily, get it painted
I'd get someone else to do it, painting all of it is tricky as the HHKB is case mounted so you'd have to fully disassemble it and make sure the paint doesn't interfere with sliders
Vinyl wrap it if you can be bothered
Yes, but I prefer BKE redux
Novatouch sliders or KBD Fans adapt x, I never use topre without silencing rings
Buy one and you'll see for yourself
