Author Topic: Do blue alps and orange alps share the same housing?  (Read 4656 times)
Offline Ejusdemgeneris
« on: Sat, 31 March 2018, 08:40:23 »
I have recently managed to get an Apple Desktop Bus Keyboard (from a recycling centre) and some blue alps. I plan to swap some of the orange alps switches with the blue ones using the same housing without desoldering. I wonder if it is possible, thank you.
Offline Myoth
Re: Do blue alps and orange alps share the same housing?
« Reply #1 on: Sat, 31 March 2018, 08:51:54 »
All Pine Tactile or Clicky Alps SKCM housings are the same, so yes you can swap them however you like  :)
« Reply #2 on: Sat, 31 March 2018, 09:06:13 »
Thank you very much :)
« Reply #3 on: Sat, 31 March 2018, 14:41:41 »
The important takeaway from all of this is,  Orange is a Superior Color to Blue..
Offline ander
  • I type, therefore I am
« Reply #4 on: Sun, 01 April 2018, 04:00:01 »
Yes, but the Oranges have to use the rear entrance.
« Reply #5 on: Sun, 01 April 2018, 09:38:31 »
I'd xpect n-turtle to come in here and say something like,  Some people prefer it. !
Offline rich1051414
« Reply #6 on: Sun, 01 April 2018, 19:10:05 »
Orange and blue alps share the same everything other than click leaf and spring. I assume the springs are different anyway. Even the sliders are the same, except for the color :)
« Reply #7 on: Sun, 01 April 2018, 21:02:28 »
I will try them out first and if I don't like them I will swap them back. Thanks though!
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #8 on: Mon, 02 April 2018, 08:31:19 »
Blue is not only better than orange, but the switches are nicer too!  :p
« Reply #9 on: Tue, 03 April 2018, 05:32:35 »
Sorry, but what about the switchplates? Just realised that I cannot swap the switchplates without desoldering the switches. Thank you for responding guys.
Offline Torque_635
« Reply #10 on: Tue, 03 April 2018, 09:43:51 »
Known as top modding.
Swapping out everything but the switch plate.
I've done this to an AEK II where I had several M0116 keyboards and made an AEK 1.5 ;)
Offline rich1051414
« Reply #11 on: Tue, 03 April 2018, 14:34:33 »
I can feel a difference in the white and gray switchplates, but I don't know if it is condition dependent or what. The gray ones seem to be felt less than the white ones, from my examples.
Either way, pretty sure blue and orange alps both use gray switchplates.
« Last Edit: Tue, 03 April 2018, 14:36:38 by rich1051414 »
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #12 on: Tue, 03 April 2018, 14:45:49 »
Most of the time, yes.
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #13 on: Tue, 03 April 2018, 16:49:36 »
It's curious that you should mention that, as I've wondered myself if the white switchplates are what give white Alps its harsher feel.
I removed the switchplate from an Omron B3G-S switch (after I broke it) and it was so much smoother — it felt like a whole new switch afterwards. That demonstrated just how much they do interfere with the feel of the switch.
Bore Awards
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #14 on: Wed, 04 April 2018, 08:13:06 »
B3G-S switchplates are compatible with Alps?
  • RIP
    • Boring twaddle
« Reply #15 on: Wed, 04 April 2018, 18:44:14 »
No — why would you think that?
Bore Awards
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #16 on: Wed, 04 April 2018, 19:10:23 »
Oi I misread, thought you meant that you put an Omron switchplate in an Alps switch since the Omron was broken anyways.
