Author Topic: Can anyone tell me the switch type?  (Read 4580 times)
Offline buckyballs
« on: Sun, 29 April 2018, 10:16:34 »
I saw this ad locally and got quite curious. What switch type are these? I've heard that Apple makes good keyboards, but is this board any good?
Re: Can anyone tell me the switch type?
« Reply #1 on: Sun, 29 April 2018, 10:31:24 »
If that is like the one that I had, it is truly dreadful.
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
Offline TalkingTree
    • My projects
« Reply #2 on: Sun, 29 April 2018, 10:34:06 »
Looks like a Apple A1016 to me. Rubber dome.
« Reply #3 on: Sun, 29 April 2018, 10:58:07 »
That one is horrible.
Apple has not made a mechanical keyboard since 1995. The one you posted is from the second Jobs era.
Offline buckyballs
« Reply #4 on: Sun, 29 April 2018, 11:06:40 »
The side profile picture looked kinda of mechanical, so I was wondering maybe if I offered the seller five bucks I might end up with a nice alps board?
Sorry but I always thought a rubber dome involves, well, rubber. And the side profile didn't look like rubber to me.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #5 on: Mon, 30 April 2018, 09:17:49 »
They don't look anything like Alps. It's a pretty common slider over rubber dome design. The sliders you see push the rubber dome onto the membrane. Your average rubber dome uses the same design, except that the slider is integrated into the key. If for some reason you still don't believe us, here is video proof:
Offline buckyballs
« Reply #6 on: Mon, 30 April 2018, 11:46:13 »
Wow, this video makes me want to buy the keyboard and restore it, if only for the experience!
But seriously, the video reminds me of the IBM Model M...also a kind of weird hybrid where there are mechanical keys on top but a membrane underneath...
Offline Kevadu
« Reply #7 on: Mon, 30 April 2018, 13:49:38 »
It's not mechanical at all though.  Those are rubber domes...
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #8 on: Mon, 30 April 2018, 14:03:55 »
Calling the sliders mechanical is incorrect. You might as well call all rubber domes mechanical since they use the exact same mechanism.
Offline klennkellon
  • I like bottoming out
« Reply #9 on: Mon, 30 April 2018, 16:04:15 »
It's a dome with slider of an especially horrific type iirc. Mid 2000's apple domes are a special kind of bad.
Offline _rubik
« Reply #10 on: Mon, 30 April 2018, 16:14:14 »
What are ... 'mechanical keys'?
Offline Kevadu
« Reply #11 on: Mon, 30 April 2018, 16:34:31 »
Keys that follow the laws of classical mechanics.  Ergo, all keys are mechanical.
Offline buckyballs
« Reply #12 on: Mon, 30 April 2018, 18:50:03 »
I'm starting to understand. A mechanical keyboard is not one that follows mechanical laws, but one that uses springs? I think all kb that are classified as Mechanical have springs. This Apple keyboard, by virtue of using rubber domes to pop up that plastic slider after you depress the switches, is not mechanical because it doesn't use springs.
Offline Kevadu
« Reply #13 on: Mon, 30 April 2018, 20:09:14 »
OK in all seriousness nobody seems to really agree on what the definition of 'mechanical keyboard' is.  Besides 'not rubber dome over membrane' I guess.  Because back in the day when most of these technologies were invented they weren't called 'mechanical keyboards' at all...they were just called 'keyboards'.  Yet there's a huge variety of different mechanisms that can make a keyboard work.  Some are good and others not, but they're all 'mechanical' in some sense of the word.
It was only after cheap rubber dome over membrane keyboards started taking over the industry that the distinction started to be made.  Because while rubber dome over membranes keyboards are very cheap to manufacture they also have a lot of properties that keyboard enthusiasts don't like.  Not the least of which is the fact that they don't actuate until you've bottomed out the keys, while most 'mechanical' keyboard actuate midway through the keystroke.
« Reply #14 on: Mon, 30 April 2018, 20:45:31 »
-Ergo-  DOX.. !!
