Author Topic: Any ya'll still using CCFL Monitors ?  (Read 4835 times)
« on: Mon, 07 May 2018, 06:53:40 »
So Much Color Drift, So Warm.
-Hipster Intensifies-
I have a feeling eventually hipster will latch onto CCFL backlit lcds, and be like, Oh yea dat color, So warm and Much analogue..
Hahahahaha..
Offline fanpeople
Re: Any ya'll still using CCFL Monitors ?
« Reply #1 on: Mon, 07 May 2018, 07:23:12 »
Hipster intensifies.... next thing you will turn to vegan orthodoxy.
« Reply #2 on: Mon, 07 May 2018, 07:40:43 »
What about mice with roller balls??
« Reply #3 on: Mon, 07 May 2018, 09:55:14 »
I still use the original microsoft intellimouse ball mouse on my computer with the 17 inch 5:4 monitor.
Can't really use it for anything higher res than that because it's too slow and imprecise.
« Reply #4 on: Mon, 07 May 2018, 15:22:32 »
What a weird Monitor..
I just calibrated an oldie , viewsonic va2323wm.
The User-Set color settings on the monitor side (to match white point) Does not kick in once the monitor turns off, UNTIL you re-enter the color menu manually..
The settings stay in the menu, but it doesn't activate until you go INTO the menu after every power cycle
I doubt anyone has ever used this cheapie monitor for color-work,  but had they done so, unless they knew about this defect, they would've woken up to the wrong colors each and every time the monitor power cycles..
« Reply #5 on: Mon, 07 May 2018, 18:24:21 »
I don't even know if my monitor is backlit or ccfl, that's how much I care
« Reply #6 on: Mon, 07 May 2018, 18:31:50 »
what's the model.. !!
Offline Prelim
« Reply #7 on: Thu, 07 June 2018, 12:21:49 »
Still on a HP W2207H here ;)
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
« Reply #8 on: Thu, 07 June 2018, 12:33:53 »
HP LP2065 official specs don't say, nor do these more detailed ones
It's old and square so sounds like something a hipster would like...
Offline meepmeep
  • meep meep meep, meep meep meep. Meep!
« Reply #9 on: Thu, 07 June 2018, 17:17:40 »
Are there any benefits to using a CCFL monitor?  aside from the accompanying high pitched whine?
Offline fanpeople
« Reply #10 on: Wed, 11 July 2018, 03:51:56 »
The feeling of either elite superiority over those who take to new technology like a common prostitute to a crisp 50. That or the smug satisfaction of a penny pinching lord of 5 estates..... or the depression of a bum down on their luck.
Feelings.
Offline JianYang
« Reply #11 on: Wed, 11 July 2018, 04:22:54 »
Last I checked, gamut is usually better with CCFL, but it might have changed since. My CCFL monitor has a low pitched whine at 50Hz.
Offline Coreda
« Reply #12 on: Wed, 11 July 2018, 04:42:27 »
I can't remember if this was a joke on tp's vegan ways at the time or a surprisingly accurate prediction :p
Offline fanpeople
« Reply #13 on: Wed, 11 July 2018, 04:47:23 »
As much as i want to claim the prediction, it was during the tp vegan period.
