Author Topic: Unicomp model M broken  (Read 2744 times)
Offline aapje
« on: Tue, 08 May 2018, 08:06:27 »
My 2015 unicomp keyboard just died. They keyboard resfused to work so I plugged it back in again. The USB device was not functioning according to the device manager. I disabled en re-enabled the device and it worked again for a few seconds. Then a message popped up saying USB device not recognized.
It also won't work on another PC. I removed the casing and the wires look fine. I removed the little PCB en and plugging everything back in. Also peeled some of the cable. There are no broken wires visible. Can I order a new USB cable somewhere?
This is my second unicomp keyboard dying within a few years with hardly any use. So far I'm not really impressed by the quality  :'(
Offline ag36
Re: Unicomp model M broken
« Reply #1 on: Wed, 09 May 2018, 05:54:37 »
Sounds like you need a new controller, have you thought letting unicomp or it's distributor to repair it?
Model M*5, SSK*4, M13 black*1, Model F XT*1, AT*1 F107*1, Unicomp*1, 3278 *1, Leopold FC750R*2, 980M*2 FC980C*1 Filco majestouch 2 TKL*1, Cooler Master MasterKeys S PBT*1, Uniqey Q100*2, Ducky pocket*1, KBD75*2, KBD19X*2, HHKB pro 2*1, Type-S*1 Topre Realforce RGB*1, 108 all 30g*1, numpad*1, 87U*1 Dell AT101W*2, Alps64*2, V80 matias quiet click*2, Quiet liner *1, WYSE ASCII *1
Offline standay
« Reply #2 on: Wed, 09 May 2018, 08:14:37 »
Yep. I had a model M that was doing that and I had to replaced the internal controller card. Easy to do.
Offline ag36
« Reply #3 on: Wed, 09 May 2018, 08:41:02 »
Unfortunately model M controller are incompatible with unicomp's usb membrane so you need to order a new usb controller through, otherwise is a 1 minute job. I guess that'll save you a lot of shipping cost if you do it you self.
Offline standay
« Reply #4 on: Wed, 09 May 2018, 09:38:03 »
Yes, good point. There are differences within versions of the model Ms too. So you have to be sure to order the right thing.
« Reply #5 on: Wed, 09 May 2018, 18:30:23 »
That's weird,  these are low power devices.. hrrrmm.. Does your house circuit have an Earth Pin,  or do you live in a country where it's just 2 prong.
