Author Topic: How to make sure all parts are compatible in a build?  (Read 1747 times)
Offline Kandza
« on: Sun, 20 May 2018, 16:26:20 »
I have a keyboard in mind that I want to build, and I'm wondering what the best way is to go about to make sure all the parts are compatible.
Should I start finding a PCB that works for the layout I wish and go from there? Or should I look at plates, keysets, etc? Thanks :)
Offline xondat
  • i'm not a star
Re: How to make sure all parts are compatible in a build?
« Reply #1 on: Sun, 20 May 2018, 16:27:46 »
Usually start with the PCB/plate, make sure they match.
If it's MX, then most works with each other. Depends what form factor though, and the extent of what you mean.
« Reply #2 on: Mon, 21 May 2018, 10:32:34 »
That's easy just keep buying moar keyboards until something fits somewhere. It's not a problem because eventually there will simply be a continuous torrent of keyboards being built, used loved, shelved and forgotten
Offline jlee755
« Reply #3 on: Mon, 21 May 2018, 11:10:53 »
I would start with your desired layout and work from there. As mentioned above, you look for a PCB/plate combo that would fit that layout and then a case.
If your desired layout is unique/niche enough and you don't feel like designing a PCB, you may have to hand-wire your own layout along a custom plate.
Offline longsock
« Reply #4 on: Thu, 24 May 2018, 14:15:05 »
Make sure that the plate and PCB is compatible. Thats the most important part  :thumb:
QXP | HHKB Pro 2
Incoming: Duck Viper V3
