Author Topic: The most quiet tactile switch?  (Read 14673 times)
Offline Row009
« on: Sun, 03 June 2018, 16:04:33 »
Hello,
I do research at a university facility that requires quiet. I use a laptop with a scissor switch keyboard (obviously).
I was wondering if there is a tactile switch that can be comparable sound wise?
Iv'e used a few types of switches in various keyboards (mostly Cherry and Cherry Compatible - haven't had the chance yet to sample the many non-Cherry types), and I currently use Cherry Blue at home (Which, although dampened by O-rings, produces quiet a lot of sound).
Offline Sneaky Potato
  • Gunslinger
Re: The most quiet tactile switch?
« Reply #1 on: Sun, 03 June 2018, 16:09:57 »
Matias Quiet Click are really quiet, and nicely tactile. I really enjoy them. Used them for several months at work and my board was significantly quieter than most of the other keyboards.
I think if you put Zealencios on anything, they get a lot quieter. I used Ergo Clears with them as well, and they’re great if you need to be quiet.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #2 on: Sun, 03 June 2018, 16:14:31 »
Hello,
Zilents. The tactile switches sold by zeal PC
Sent from my mobile using Tapatalk
Offline Colourr
  • no worries
« Reply #3 on: Sun, 03 June 2018, 16:48:47 »
I'm a huge fan of Zilents!
Offline zslane
« Reply #4 on: Sun, 03 June 2018, 16:49:19 »
Go with the gold standard in tactile switches: Topre. If you want really quiet, either look for one that is factory silenced, or install silencing rings yourself (it is tedious, but worth it).
« Reply #5 on: Sun, 03 June 2018, 17:21:44 »
Perceived tactility is a combination of Sound and Touch..
If you remove the Sound, the Touch alone will feel just like Friction.
It's the combination of Sound and Friction which produces that Twig-snapping/ Bubble popping experience.
Offline Kevadu
« Reply #6 on: Sun, 03 June 2018, 17:54:03 »
I would also recommend Zilents.  They are seriously quiet.
Also tp4 is crazy.  Sure the entire keyboard experience involves sound too, but to claim that tactility depends on sound is contrary to what those worlds mean.  That's like saying that appearance depends on smell.
Offline ramblinrose
« Reply #7 on: Sun, 03 June 2018, 17:56:50 »
I find my cherry clears pretty quiet as they are easier to not bottom out. As long as I'm not pounding the spacebar and backspace it's a nice quiet switch on my leopold 750r!
Offline Row009
« Reply #8 on: Sun, 03 June 2018, 18:26:01 »
Thanks everyone. I'll certainly look further into your recommendations.
Offline ygor
  • eat a butt, monkey lord
« Reply #9 on: Sun, 03 June 2018, 18:27:06 »
Pretty sure KBDFans just made a silent tactile switch... Same as the new Cherry linears with the bumpers on the stem.
Offline bitzie
« Reply #10 on: Mon, 04 June 2018, 13:23:07 »
Aliaz switches. They are ok, about as tactile as Cherry MX Browns.
Zilents are the way to go.
Offline jcoffin1981
« Reply #11 on: Mon, 04 June 2018, 21:56:32 »
He did specify "perceived" tactility.  I will agree with his statement that sound is part of the tactile experience.
Offline glack23
« Reply #12 on: Tue, 05 June 2018, 00:27:00 »
zilents. Using that at work
Sent from my Pixel using Tapatalk
Offline zap2oz
« Reply #13 on: Wed, 06 June 2018, 22:47:50 »
Echoing what some of the other people here have said and saying Zealios. They're great!
Offline godlikekitten
« Reply #14 on: Wed, 06 June 2018, 23:06:20 »
Wanna vouch for lubed zilents.  Like soft rain drops my dude
Offline mangoes
« Reply #15 on: Wed, 06 June 2018, 23:25:38 »
Aren't zilents generally agreed upon to be the quietest? Regular zealios are loud as hell in comparison, and even my hhkb type s sounds loud in comparison
Although that might need I need to lube it again or something...
Offline johngodsmith
« Reply #16 on: Thu, 07 June 2018, 04:43:38 »
Think everyone covered it already. Other than zilents and aliaz
there's also gateron silent browns
« Reply #17 on: Thu, 07 June 2018, 10:21:33 »
The Aliaz is just a tiny upgrade on the Gateron Silent Browns. Both were made by Gateron.
However, they are still browns and therefore not very tactile.
Zeal PC's "Zilents" switches feel more like Cherry MX Clear, but smoother. Also made by Gateron. Really expensive though.
However, these three are more silent than any other MX-compatible switches with any kind of mods to make them more silent.
Then you should also consider which keyboard you put them into. Even some very silent switches would be noisy in the wrong keyboard.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #18 on: Fri, 08 June 2018, 17:30:38 »
^  This, but I would highly recommend buying the factory silent version instead of doing it yourself.
Offline hilltopchill
« Reply #19 on: Fri, 08 June 2018, 20:41:58 »
Zilents or silenced topre would be your best bet.
