Author Topic: Any 1 know how do Basement Pipes ?  (Read 3126 times)
« on: Sat, 09 June 2018, 07:52:10 »
So,
Tp4 bought des' PVC pipes and PVC joint-fittings
Only to find out the older pipe is ABS (cellular core) cheapo pipes..
Now, Internet says haz to use _Transition Cement_
The PVC glue has a primer+cement portion for plastic welding.
So, if I use the pvc-fitting  on one end with PVC pipe, and the OTHER end to old ABS pipe,   Do I NOT prime the other side of the fitting where it connects the ABS ?
Re: Any 1 know how do Basement Pipes ?
« Reply #1 on: Sat, 09 June 2018, 09:02:38 »
I think that you need the "transition" cement:
http://www.plumbing-geek.com/solvent-cement.html
Also, you didn't say whether these were supply or waste pipes. Joints in supply lines are critical, waste lines less so.
« Last Edit: Sat, 09 June 2018, 15:20:24 by fohat.digs »
- D Trump 2026-10-24
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2 on: Sat, 09 June 2018, 11:48:39 »
I wouldn't PVC weld ABS..
Offline JP
« Reply #3 on: Sat, 09 June 2018, 16:10:15 »
Tp4 is now a plumber.
About Me | The Collection
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #4 on: Sat, 09 June 2018, 16:57:26 »
The only experience I have with PVC piping is some six months of installing HVAC systems. PVC welding ABS seems like a bad idea. #twocents
« Reply #5 on: Sun, 10 June 2018, 10:56:09 »
They're fixed..
Now to pray for 5 hours while the glue cures..
What direction do i face for plumbing god.
Tested the transition cement on the outside of both abs and pvc pipe,  it was melting into both.. So I asssume that it should weld the 2 together..
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #6 on: Sun, 10 June 2018, 11:18:29 »
*CLAPS* another home improvement job well done
« Reply #7 on: Sun, 10 June 2018, 16:43:23 »
Seems like there's no leak..
Non pressure system so, not super worried..
Offline typo
« Reply #8 on: Sat, 16 June 2018, 17:29:44 »
If you plan to stay there 15 more years. Put in all PVC Sched 40/80. Supply all Red copper or Pex. Does not sound DIY for you TP. Just figure the home is only 2,500 SF. Looking at 40 grand.
Wait until there is a leak and you don't know it Buddy. Maybe 40 grand anyways.
