Author Topic: You might be a hacker IF...  (Read 7088 times)
Offline digi
  • elite af tbh
  • keyboard game on fleek
« on: Thu, 05 July 2018, 16:53:16 »
You have Anonymous .jpg set as your wallpaper on a Linux distro..
Re: You might be a hacker IF...
« Reply #1 on: Thu, 05 July 2018, 17:02:18 »
...you're a geek.
Offline digi
  • elite af tbh
« Reply #2 on: Thu, 05 July 2018, 17:09:40 »
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #4 on: Thu, 05 July 2018, 19:40:10 »
...you're a geek.
dang
Most peeps really just need a cool haircut..
Don't skimp at the salon folks..
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #5 on: Thu, 05 July 2018, 20:08:56 »
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #7 on: Thu, 05 July 2018, 21:26:32 »
Yep.
You're quite skilled with the curling iron.. /Nice
You should see my crimping iron collection
« Reply #9 on: Thu, 05 July 2018, 23:14:18 »
You are proficient with the hacksaw.
This is the original meaning of the word from which all other meanings of the word have developed from.
BTW, by this definition, I would consider myself a very proficient hacker.
Offline digi
  • elite af tbh
« Reply #10 on: Thu, 05 July 2018, 23:31:48 »
"2. a person or thing that hacks or cuts roughly."
Hey guys I'm cutting rough today, I'm hacking. tehee
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #11 on: Fri, 06 July 2018, 00:35:04 »
haha
« Reply #12 on: Fri, 06 July 2018, 08:42:10 »
haha
Tp4 styles using dat hair-dryer
Offline JianYang
« Reply #13 on: Fri, 06 July 2018, 08:49:33 »
Yep.
A true hacker would have used a soldering iron ;D
« Reply #14 on: Fri, 06 July 2018, 09:36:14 »
Yep.
Theoretically possible..
If you got a hakko with the heat low enough.   I don't see why it wouldn't work.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #15 on: Fri, 06 July 2018, 09:52:23 »
Yep.
True. A nice steel wool tip cleaner action and that iron will be ready to thoroughly rock that hair.
Offline JianYang
« Reply #16 on: Fri, 06 July 2018, 12:28:32 »
Yep.
hakko with low heat is for beginners. You have to work fast enough to do it at 370C. That way you don't lose any time when you switch back to lead-free
« Reply #17 on: Fri, 06 July 2018, 13:43:15 »
Hhaahahhaahahahahahahahahahahahahahahahahahahahah
Offline iri
« Reply #18 on: Sat, 07 July 2018, 07:57:28 »
-Ray Bradbury
Offline JP
« Reply #19 on: Sat, 07 July 2018, 09:06:21 »
You use Emacs.
About Me | The Collection
« Reply #20 on: Sat, 07 July 2018, 09:59:00 »
You use Emacs.
I use Spacemacs. Does that count?
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #21 on: Sat, 07 July 2018, 10:06:25 »
Offline JP
« Reply #22 on: Sat, 07 July 2018, 13:20:17 »
Also a hacker should use this keyboard  ;D
Offline algernon
  • A tiny mouse, a hacker.
    • Diaries of a Madman
« Reply #23 on: Sat, 07 July 2018, 14:33:20 »
No.
« Reply #25 on: Sat, 07 July 2018, 21:48:38 »
I have once tried out that exact keyboard. It belongs to webwit.
« Reply #26 on: Sun, 08 July 2018, 00:25:13 »
Apparently you have to practically be a hacker to use this website since it is so hard to navigate.
Offline SBJ
  • Tactile pls
« Reply #27 on: Sun, 08 July 2018, 02:18:48 »
:confused:
I don't get it. This is straight forward imo.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #28 on: Sun, 08 July 2018, 10:56:25 »
:confused:
Yea seriously, and it's easily searchable.
« Reply #29 on: Sun, 08 July 2018, 11:06:33 »
:confused:
It really is http://bfy.tw/IwcW
