Author Topic: Switches recommendation for an ergodox  (Read 9888 times)
Offline iocanel
« on: Fri, 13 July 2018, 16:43:49 »
I want to get an ergodox, but I can't decide on what kind of switch to use.
So far, I've decided that I want "gateron clear" for thumb and modifier keys (they feel really light and easy to press), but I can't make my mind on the rest.
I am a software developer, so my main activity will be coding.
I currently have a Realforce with Topre switches, but I can't say I am happy with Topre (they cause fatigue).
I've used a tester, but it didn't help as I wasn't able to find something that I really like:
- Blues/Greens: too clicky.
- Browns: not smooth enough.
- Reds: no feedback
Keyboards that I liked:
- mackbook pro
- lenovo p50
- razer with mecha-membrane
Which do u think is the right switch for me?
Re: Switches recommendation for an ergodox
« Reply #1 on: Sat, 14 July 2018, 00:10:49 »
I would suggest Gateron Silent Brown.
- smoother than Cherry MX (although I have heard some batches of Cherry MX Brown are smoother than others)
- slightly more feedback than MX Brown because of stiffer component inside
- silenced, in the same way as Cherry MX Silent Red and Black
Offline MatchstickMan
  • CAD Jockey - YOLO Enthusiast
« Reply #2 on: Sat, 14 July 2018, 00:53:34 »
Consider the Zeal switches? They're super smooth compared to browns and are available in a number of spring weights.
I've got 67g Zealios on mine and love them, but I also like heavy weight switches.
Current Projects:
- SouthPad -- Left-handed Numpad
- Full Split (Currently on hold)
Offline iocanel
« Reply #3 on: Sat, 14 July 2018, 01:27:23 »
How do they compare to the non silent version of Gateron brown?
« Last Edit: Sat, 14 July 2018, 01:29:03 by iocanel »
Offline iocanel
« Reply #4 on: Sat, 14 July 2018, 01:31:44 »
I'd rather something around 45g, though I am a little bit afraid of accidental clicks.
Sent from my ONEPLUS A5010 using Tapatalk
Offline iocanel
« Reply #5 on: Sat, 14 July 2018, 03:41:26 »
Just realized that zealios are not rated for actuation. So a 62g could work for me. Anyone has experience with zealios on ergodox?
« Reply #6 on: Sat, 14 July 2018, 03:51:19 »
They feel almost exactly the same. Unlike O-rings and silencing clips the silencing does not impair key travel and it silences better.
« Reply #7 on: Sat, 14 July 2018, 10:48:29 »
I have Zealios on my ergodox, but mine are also at about a 60deg tent, so accidental clicks are never really an issue.
Current Projects:
« Reply #8 on: Sat, 14 July 2018, 11:22:39 »
Click bar if you're not a heavy user..
If you type alot, clickbar is hella loud/annoying
Heavy users should go with MX Blue.. !!
The switch has very little to do with ergonomics..
It all comes down to TENTING of the split keyboard.
Once you're tented @ 55 Degrees,  73% of keyboard ergonomics issues are solved
