Author Topic: Does this Lube works for Stabilizers?  (Read 1905 times)
Offline Pavilions
« on: Mon, 16 July 2018, 12:01:04 »
I bought this lube from my local market, but I don't know if it will work with keyboard stabilizers or not? Is it suitable?
200136-0 :blank:
Offline katotaka
Re: Does this Lube works for Stabilizers?
« Reply #1 on: Mon, 16 July 2018, 12:06:07 »
I wouldn't use it as a lube, but I recommend using it between parts of certain materials, like steel screws on aluminum parts.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #2 on: Mon, 16 July 2018, 12:10:17 »
(Attachment Link) :blank:
I frankly am not sure if it'll be suitable. You'd only know if you tried. I recommend:
SuperLube 82340
Teflon lube (instead of Superlube)
Dielectric Grease for your stabilizer wires
