Author Topic: Tp4 Solder-Reel Dispenser. !!  (Read 3400 times)
« on: Tue, 17 July 2018, 11:12:52 »
You Could spend  $ 9  and buy a dispenser from Amazon...
Or, spend that Same  $ 9  on some General Tso's Chicken...
And Build the  --Tp4 Solder Dispenser--
Advantages:
-- Much easier hand access to REWIND the reel..
_____ Most commercial soldering reels do not give you large touch coverage of the reel edge..
_____ (The Tp4 Solder Dispenser does, as the reel is elevated HIGH above the lip)
-- You get General Tso's Chicken w/ your solder dispenser.
-- You get DIY p0wer ^up^
-- You get to Feel all, Tp4 !!
Addendum:  Yea, there are Numerous ways to accomplish this..   But Tp4 method is probably among the Simplest and most effective using the most Ubiquitous of Materials...
200194-0
+ General Tso's Chicken
200198-1
vs $9
200196-2
Re: Tp4 Solder-Reel Dispenser. !!
« Reply #1 on: Tue, 17 July 2018, 11:15:26 »
It's a tp dispenser!
« Reply #2 on: Tue, 17 July 2018, 12:02:59 »
What are you soldering?
« Reply #3 on: Tue, 17 July 2018, 12:06:13 »
Pics of yellow food.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #5 on: Tue, 17 July 2018, 16:09:30 »
I like that the images are the same width. One can appreciate a uniform presentation.
« Reply #6 on: Tue, 17 July 2018, 16:12:39 »
Ah.. Cough.. as much as Tp4 would like to take credit for --Presentation--..
Gekha auto resizes images with larger pixel width
Offline HotRoderX
« Reply #7 on: Tue, 17 July 2018, 16:29:33 »
I like this TP4 thank you! its a simple solution to a PITA problem. I also like that TP4 Dispenser includes General Tso chicken
« Reply #8 on: Sat, 28 July 2018, 06:25:18 »
m0ar Tso, m0ar Solder
