Author Topic: Mouse pad dimensions for testing sensors with specific finish.  (Read 8469 times)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Hey guys. Question for you. What would you consider to be the smallest practical sized mouse pad for testing surfaces/coatings?
Re: Mouse pad dimensions for testing sensors with specific finish.
« Reply #1 on: Sun, 22 July 2018, 08:12:51 »
Logitech cuts a round disk and spin it under a stationary mouse.
You can cut a rectangle,  but if it's mounted off center, you could kill someone.
