Author Topic: Be Careful of Unmarked spray bottles.  (Read 2955 times)
« on: Mon, 23 July 2018, 13:42:19 »
Little tiny spray bottle on a table..
Tp4 investigates..  damn,  it's a perfume sample..
Worse,, Bergamot...
Now will smell like that all day..
Offline juntheboon
Re: Be Careful of Unmarked spray bottles.
« Reply #1 on: Mon, 23 July 2018, 15:01:53 »
even sitting water that's just been there for a couple years smells bad
got any?
« Reply #2 on: Mon, 23 July 2018, 15:06:14 »
There are many things worse than bergamot... unless you are hypersensitive to citrus rind oil.
Bergamot oil is an oil, so wash with oil-based solvent like white spirit or lacquer thinner. Then isopropylalcohol, acetone or other degreaser to dissolve excess oil-based solvent.
« Reply #3 on: Mon, 23 July 2018, 15:36:02 »
Tp4 Activated the container while seated..
Atomized cloud directed all over pants..
Can not launder until return to base.
« Reply #4 on: Mon, 23 July 2018, 18:13:35 »
The real question is why would you spray yourself with some strange unmarked substance sitting out somewhere?
« Reply #5 on: Mon, 23 July 2018, 19:30:36 »
If you're some where relatively benign/ safe, and there's some sort of button..
« Reply #6 on: Mon, 23 July 2018, 21:29:36 »
he's always on the lookout for new superpowers
Sent from my HD10 using Tapatalk
« Reply #7 on: Mon, 23 July 2018, 22:02:38 »
« Reply #8 on: Tue, 24 July 2018, 04:45:38 »
Have you never seen a big friendly red button and not had the urge to press it?
« Last Edit: Tue, 24 July 2018, 13:36:43 by Findecanor »
« Reply #9 on: Tue, 24 July 2018, 10:02:15 »
Have you never seen a big friendly red button and <em>not</em> had the urge to press it?
Well usually, there's like a sign,  so Tp4 looks for that..
If it says cut-power or emergency, or purge coolant,  Tp4 would certainly avoid it..
But if it seems to hook up to some ceiling fans, or something,  Temptation may be high.
