Author Topic: [Hyperx-Alloy Fps Pro] NEED HELP/ADVICE  (Read 1959 times)
Offline Pixeloncrack
« on: Tue, 24 July 2018, 07:58:24 »
Hi everyone,im new into mechanic keyboard world.Im planing to buy my first keyboard,since they are I will say expensive or as some people knew to say ,,investment'',I need some advices from you guys.My budget allows me to buy HyperX-Alloy Fps Pro.I dont have to much choise because in my country other keyboards are expensive,and there are not many to choose.
I want to know how good it actually is,is it reliable,will it last.
I have read about it on https://www.tweaktown.com/reviews/8405/...ndex4.html , but really want to hear someone else.
That PCB looks dirty,will it cause any problems in future?
Can i repair it if switch/led broke,usb connector or so.Im planing to buy something which i can fix by myself.
Thank you for stoping by and reading!
Re: [Hyperx-Alloy Fps Pro] NEED HELP/ADVICE
« Reply #1 on: Tue, 24 July 2018, 08:48:02 »
Definitely wouldn't recommend that keyboard..
The top will probably rust pretty easily
If you're looking for an exposed top board,  look for aluminum top..
Steel sounds good , but it's just not good if it's painted steel plates, like most of these probably are.
« Reply #2 on: Tue, 24 July 2018, 14:58:32 »
Thank you for your advice man appreciate that.
Is there any keyboard in price range 80-90$ worth looking at,Im from Serbia im trying somehow to not pay extra money for import taxes.
Anything from Aliexpress more desirable and cheaper than HyperX one?
I saw some Anne Pro keyboard.
« Last Edit: Tue, 24 July 2018, 15:17:16 by Pixeloncrack »
